#1 |
![]() Join Date: Nov 2007
and about a million other threads. im not used to these lil cars. im wantin a 00-02 motor in my 98 dual overhead sc2 5spd. can i get away with the stock trans and ecu with minimul mods? any major stuff i need to do? its just a daily driver and i want a lower miles motor for it. whats the thoughts on putting an 00-02 ecu and wireing harness in a 98? what all will i need?
#2 |
![]() ![]() Join Date: Jan 2006
2002 SC1
Can I ask why are you wantin' a '00-'02 engine in a '98? They were not a better desing, and they are bogged down with an AIR pump. The tranny will work no problem, but the PCM is a different story, I'm quite certain it won't. Along with that, the head is a different design and the intake and exahust manifolds need to be carried over with the newer engine. I think those are the major issues for you. Low Saturn is the expert in...well just about everything mechanical about hese cars, and especially engine sawps.
Aut viam inveniam aut faciam ... If your ECTS is not brass...your ass is grass. ... If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy. |
#3 |
cant find a low miles 98. i threw a rod at 160K about a month after i bought the car. and all 98s i found were 100-150k and i just need something reliable. and something i wont have to keep throwing money at
#4 |
2002 SC1
If it's just a rod, you could find a bottom end, since pretty much all of the changes were to the head after 1999. That's if you trust your head. Maybe a newer bottom end and a mild rework of the head? Might be easier than swapping the whole thing, depending how good you are around motors.
#5 |
id rather go with the whole motor im just now getting into the economy car scene. (gas prices) im more of a ford small block guy.
#6 |
Tranny should work no problem. '98-2002 are all the same trannies. PCM...i think that will work also. the manifolds switched in '99 so you can use your '98 manifolds. and you will have to use your '98 fuel rail. other than that, it really should be plug and play
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place |
#7 |
2002 SC1
#8 |
forgot the "t".
![]() you can not use the '98 manifolds ![]()
#9 |
would i need a motor out of a manual car? or would an auto car work too? i heard the fly wheels were different. mines a manual
#10 | |
![]() Join Date: May 2004
2000 SC2
![]() Quote:
This is what I did. I installed a 2002 block into my 1997 SC2. Mine had spun a bearing. The 2002 block was from a car with an auto transmission. The head, timing set, transmission and all bolt ons were 1997. I wanted the newer block because I had read here on SaturnFans that the ring design was better, used less oil, and the crankshaft was somehow stronger.
MikeH |
#11 | |
2002 SC1
![]() Quote:
#12 |
do yall know how i can get ahold of someone who has done the swap. the pcm is my biggest concern at the moment. arent they manufactored by different companys?
#13 | |
![]() Quote:
For the PCM i suggest keeping the '98 PCM. Keep the 5spd tranny and just drop the new engine in. more then anough member here have done engine swaps. LowSaturn is the swap master haha ![]()
#14 |
2002 SC1
Member Low Saturn is the "Engine Swap Guru."
#15 | |
![]() Quote:
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone* 2007 Chevy Equinox LT 205K miles 2018 Chrysler Pacifica Touring L 74K miles |
#16 |
2002 SC1
There shouldn't be any driveability problems, it's just emissions control. Are you sure your SES light works? Does it light up at start up? I didn't know it was possible to run without it, if your SES light works, I wonder how they got around the AIR pump. Maybe an older PCM?
#17 | |
![]() Quote:
#18 |
![]() Join Date: Aug 2005
CHeck out my parts guide:
http://www.saturnfans.com/forums/sho...d.php?t=111015 If you want me to add anything to it, please let me know! |
Bookmarks |
S-Series Swap Guide | Uzzy | S-Series Tech | 303 | 08-20-2020 01:33 AM |
96 sc2... which years of window regulators will swap? not found in swap guide... | DJboozeAlot | S-Series Tech | 3 | 08-07-2012 05:45 PM |
Swap guide | richamer1 | S-Series Tech | 8 | 12-05-2007 11:01 PM |
what happened to the swap guide | 94503 | S-Series General | 1 | 05-14-2007 07:43 PM |
TSN swap guide anyone? | geartooth94 | S-Series Mods | 5 | 10-24-2006 09:00 PM |
