Old 10-30-2007, 10:27 PM   #1
ns087
ns087 is on a distinguished road
Default What exactly is a reverse slam?
I'm new here and people talk about it and I think my car Might have it too but I'm not sure
ns087 is offline   Reply With Quote
Old 10-30-2007, 10:32 PM   #2
MotorMan
MotorMan is on a distinguished road
Default Re: What exactly is a reverse slam?
When you put your car into reverse, there is/could be a pause then.....Wham......the car jolts into reverse....... Reverse slam!
MotorMan is offline   Reply With Quote
Old 10-31-2007, 07:20 AM   #3
2NDSOUT
2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light
2NDSOUT's Avatar
1999 SL
What he said. It's only in Automatic Transmissions...I haven't heard of this happening in manual transmission cars.
There is a how-to by Wolfman in the help section to help you diagnose if you indeed have this issue.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 10-31-2007, 10:35 AM   #4
webbkarz
webbkarz is on a distinguished road
It does only happen in automatic cars. The end nut on the output shaft tends to loosen up. It entails of removing the end cover, replacing the nut and torqueing it to spec. If not repaired, it can actually cut a hole in the trans case. It causes low pressure problems in the trans, and since reverse takes full pressure you get the "slamming" into reverse after pressure builds up.
Del
webbkarz is offline   Reply With Quote
Old 10-31-2007, 10:58 AM   #5
webbkarz
I meant input shaft. My bad.
Del
Old 10-31-2007, 11:05 AM   #6
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
What exactly is slamming?
OU812 is offline   Reply With Quote
Old 10-31-2007, 01:55 PM   #7
Blammer
Blammer is on a distinguished road
1997 SW2
slamming is when you insult someone in a humous way....
97 SW2 270,000 miles and died when a tree fell on it.
Never argue with an idiot, they will only bring you down to their level and beat you with experience.
Blammer is offline   Reply With Quote
Old 10-31-2007, 03:18 PM   #8
1999greenSL2
1999greenSL2 is on a distinguished road
1999greenSL2's Avatar
If you have it, you'd know. Simple as that.
Mine has done it one time. People here make it seem like you can just sit there, shift into reverse, and while still sitting, it will slam into gear. Mine doesn't do that. The only time it did it was when I was still rolling forward, put it in reverse, and gave it gas before it finished shifting. Then it just bucked into reverse but it wasn't very violent.
1999greenSL2 is offline   Reply With Quote
Reverse Slam Valve Body replacement Reverse Fork MichelleG S-Series Tech 16 04-06-2009 06:48 PM
Reverse Slam Help banana944 S-Series Tech 10 09-28-2008 11:57 AM
Reverse Slam BillyP S-Series Tech 8 05-31-2008 11:58 AM
Is this Reverse Slam? FrugalSaturn S-Series Tech 7 05-17-2007 08:59 PM
REverse Slam Plus? zookiemike S-Series Tech 8 08-21-2006 09:33 PM
