Old 10-02-2007, 12:25 PM   #1
sinhlee
sinhlee is on a distinguished road
Default 2003 Saturn VUE Manual Transmission Fluid
Hi all,
I know that 03 Saturn VUE Manual Transmission Fluid use DEXRON III. But Can I use DEXRON VI on this Transmy ? I read information on bottle said that DEXRON VI satisfies requirements of DEXRON , DEXRON III-H , DEXRON III , DEXRON IIE. Any one has experience on this ? please advise me. I don't want it srew up my transmy. Thanks alot.
sinhlee is offline   Reply With Quote
Old 10-02-2007, 10:25 PM   #2
Default Re: 2003 Saturn VUE Manual Transmission Fluid
The part numbers from the 2003 service manaul for the Getrag manual in the VUE.
GM part number 88861800 (Canadian P/N 88861801)
Dexron three is what is called for but GM now only has the Dexron six (so far as I know) which will be fine for the trans. They improve the fluid but not normally to the point where older units can't use it.
Old 10-02-2007, 11:06 PM   #3
CrewCab
CrewCab will become famous soon enough
CrewCab's Avatar
2008 AURA XE
Originally Posted by sinhlee View Post
I read information on bottle said that DEXRON VI satisfies requirements of DEXRON , DEXRON III-H , DEXRON III , DEXRON IIE. I don't want it srew up my trans.
This is true when it is used as an automatic trans fluid.
Document ID# 1897292
2003 SATURN VUE FWD
Subject: Manual Transmission Fluid Usage In 2007 And Prior Manual Transmissions And Transfer Cases - keywords case fluid manual transmission transfer #PIP3836B - (02/05/2007)
Models: 2007 and Prior Passenger Cars and Trucks
2007 and Prior HUMMER H2
2007 HUMMER H3
2007 and Prior Saturn Passenger Cars and Trucks
This PI is superseded to add a note under concerns. Please discard PIP3836A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Use of manual transmission fluid part number 88861800 U.S. (88861801 Canada) in place of Dexron III.
Important Note: If the vehicle owners manual lists Dexron VI as the recommended transmission, transaxle or transfer case fluid disregard any information supplied in this PI. Use eSI and or the vehicle owners manual to determine what type of fluid should be used prior to referencing the below information
Recommendation/Instructions:
Manual Transmission fluid part number 88861800 U.S. (88861801 Canada) is currently available through GMSPO. Current and past model vehicles listed above with either a manual transmission or transfer case that REQUIRE Dexron III should use the above listed manual transmission fluid. This fluid is a direct replacement for Dexron III in manual transmissions and transfer cases. DO NOT use Dexron VI in place of the manual transmission fluid in any manual transmissions or transfer cases as a failure may result.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
2003 Saturn VUE - FWD
CrewCab is offline   Reply With Quote
Old 10-03-2007, 09:25 PM   #4
sinhlee
2003 SATURN VUE FWD
2007 HUMMER H3
Condition/Concern:
Thank you so much Crewcap. This information help me a lot. thanks again.
2007 Saturn Vue Automatic Transmission Fluid Change greensaturn How-To Library 13 11-04-2018 09:31 PM
How to change transmission fluid in VUE with manual transmission David 93 SL2m Vue Tech 35 06-30-2017 07:47 PM
2003 SAturn Vue Transmission Fluid Service broons1 Vue General 26 02-25-2013 05:38 PM
Saturn Vue 2003 FWD VTI transmission service manual papalima Vue General 0 11-28-2009 01:59 PM
2003 Saturn Ion Transmission Fluid rchiarito Ion Tech 4 04-05-2008 11:40 AM
