![]() Join Date: Feb 2005
I have a 98 sl2. In the past 6 months I have had a growing starting problem. after i drive any moderate distance my car will not start. I mean it doesn't even attemp to turn over. It just gives a click like the battery is dead but its not. If i let it sit for an hour or more it starts right up and drives fine. It seems it just needs to cool down.
About a week ago I have the service engine light on . I got it checked and the codes P0340 and P0708 came up. i know one is the mythical cam sensor and the other is a transmission voltage sensor. BUt a few days after I had it checked out the light went off. I just assume its one of the many quirks that come with the car. Has anyone had this strange starting problem. |
#2 | |
You obviously have an automatic transaxle (P0708). Are you sure your alternator is working correctly? Believe it or not, proper operation of the automatic transaxle is often dependant on a properly functioning alternator. OTOH, your starter may be going bad. Sometimes the starter solenoid starts to stick before it goes out completely, especially in very cold (sub-freezing) weather, but when things warm up a bit, the starter works fine with no apparent problems. Worth checking into, at the very least. In my '96 FSM, P0708 refers to "Transaxle Park/Neutral Position Switch - No Data". I don't have any personal experience with the S-series automatic, since my Saturn is a manual, but I think I read somewhere that this switch sometimes may need to be adjusted. Of course, I could be all wet and thinking of something else. Try doing a search using some relevant keywords. Maybe you can find the threads that I'm remembering that discussed these types of issues? |
well all good ideas .
As far as my tranny. Its only 30k old . The first one exploded on the way home from a state to state trip when I had 62k on the car. Wierd huh! I mean exploded!. but thats another story. The car will always start up when it hasn't been driven for a while. But if i drive about ten miles I have to leave it running anywhere I go. Because history dictates Its not going to start. I'm gonna test the starter. and give it a good tune up. But if anyone else has a suggestion let me know |
#4 | |
Next time you experience the problem, try starting it with the tranny in neutral. If that doesn't work, try holding the key at "Start" with one hand, while CAREFULLY nudging the shifter from Neutral toward Reverse and Drive with the other. If at some point the starter catches, that points to a neutral safety switch that needs adjustment or replacement. Or it could the wiring or the connector to the NSS. |
97 Saturn SL1 Starting Prob | phillfam99 | S-Series General | 6 | 04-04-2007 06:37 PM |
96 sl2 stereo prob, no sound, wiring prob? speaker prob? | mjollnir79 | S-Series Tech | 3 | 09-22-2006 09:15 AM |
95 SL1 idle prob and temp prob | atilla | S-Series Tech | 10 | 06-08-2006 01:49 PM |
staring prob 96 sl2 | mjollnir79 | S-Series General | 1 | 04-13-2005 07:35 PM |
Seat belt prob in 91 SL2... | Dach | S-Series Tech | 1 | 01-24-2002 09:28 PM |
