Old 09-17-2021, 11:45 AM   #1
crosscountryLs1
crosscountryLs1 is on a distinguished road
Default Rocker Panels
So after 20+ years now, It is time to do the rockers on my 2000 L- Series 4 door 2.2L
My body guy can't find pre-cut rockers for this and we talked about trying to source rockers from somewhere in the states? I don't like the idea of him welding a different kind of metal in there. But Not sure what to do.
crosscountryLs1 is offline   Reply With Quote
Old 09-17-2021, 03:04 PM   #2
floridasl22002
Default Re: Rocker Panels
You have to acknowledge the reality that the L series has been out of production for 16 years and Saturn as a company has been closed for 13 years.
That in itself, tells you that many parts for these orphan cars are going to be only obtainable as used from junkyards or maybe Ebay.
If your body guy is more than just a welder, then building custom panels to weld where the panels have been removed due to rust shouldn't be beyond his skills. As for the metal, it's gonna be plain old sheet steel. Usually, prior to welding they spray with a galvanizing coating, then post welding and after the welds have been cleaned up, they can be sprayed with cold galvanizing to help protect them.
Old 09-17-2021, 08:03 PM   #3
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
They sold many times more of these cars in Europe as a Vectra B. Repair body panels are available on ebay/UK.
2002 L200/5 Loaded, over 1/4 million miles!
Old 09-17-2021, 11:30 PM   #4
For wrecking yards around the country go to http://www.car-part.com. I've purchased from wreckers on that site without any difficulties. Otherwise, look through a local/nearby LKQ Pick Your Part self-serve wrecking yard and check their inventory. Remember, all '00 through '02 L-Series sedans are using the same black rocker trim panel. https://www.lkqpickyourpart.com/parts/
371K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct...too bad... now Russia?!
Old 09-29-2021, 02:56 PM   #5
crosscountryLs1
looks like the Vectra B panels are in stock and hopefully is the solution
Thanks
Old 10-01-2021, 09:37 PM   #6
BrandonKastning
BrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the rough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Information Re: Rocker Panels
pierrot,
Great sources.
I wanted to add that in my State (Washington); we have "Pick N Pull"; I used it several times for my repairs.
https://www.picknpull.com/
Best Regards,
Brandon
Looking for rocker panels for a redline vue Tom16078 Vue Red Line 1 06-11-2020 08:56 PM
1994 rocker panels daynewman S-Series Tech 7 11-14-2018 11:41 AM
Wet rocker panels C152 Astra General 1 04-09-2016 08:52 PM
Defective rocker panels? cisco0623 Aura General 6 03-04-2008 06:45 PM
Rocker Panels SpeedPlayer 97sl2 General Saturn Discussion 2 09-03-2000 10:57 AM
