Thread Tools | Display Modes |
![]() ![]() Join Date: Jun 2009
2008 Astra XR
Got this from the February 2011 GM Tech Links http://www.sandyblogs.com/techlink/2011/02/
Model Year 2008-2011 Vehicle Line / Condition Astra, Aveo, Cruze, Wave - Engine lack of power with DTCs P0011, P0014, P000A, P000B, P0012, P0015 or engine rattle noise Do This Remove the oil filters from the camshaft position actuator solenoid valves Don't Do This Don't replace the camshaft position actuator solenoid valves Reference Information / Bulletin Number 10-06-04-016
Astra XR-3-5 HP - Hamster Powered! Dealer added options, & Infinity speakers. |
#2 | |
![]() Join Date: May 2009
2008 Astra XR
Interesting... I have the engine rattle noise but am not experiencing any power-loss issues. So I'm not too worried just yet. Should I? I'm at 19k miles. |
![]() Join Date: Jun 2008
2008 Astra XE
I just had mu Astra in today, and the dealer performed this repair under warranty. I originally had a check engine light come on last Sunday, and it went off yesterday, but the codes were still stored.
The car is running much better now. There is no dead spot (hesitation to rev) between 2200 and 4000 rpm, like I had before. The engine revs freely all the way to red line now. |
![]() Join Date: Mar 2010
2009 Astra XR
Has anyone noticed hesitation while idling? as if the alternator was going/car stalling, my car occasionally (maybe once every 2 months) does this. haven't really noticed any issues though, it drops for a split second then comes back up.
Eibach 15mm 5x110 hubcentric spacers with bolts PM is key! Twilight Blue XR 3 Door |
#5 |
![]() Join Date: Apr 2009
I get it from time to time too...
09 Astra XR (manual, 3-door) |
Yes, me too. I remember this coming up in a thread, and there are quite a few people that experience the little near stall and recovery every couple of months.
Drives: 2014 Volt, 2017 Acadia Past Cars: 08 Astra, 15 Acadia, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S |
#7 |
Yes, and more often than I used to. Approach a traffic light, clutch in, and there's a brief stumble that feels as if it's about to stall (but it never does). Can this be related?
Former: 2005 L300, 2007 VUE Green Line Current: 2008 Astra XE |
#8 | |
2008 Astra XE
Now that they made the fix, my car feels better than new. |
#9 |
![]() Join Date: Jul 2008
My check engine came on today, Onstar says the code is P0011.
I had the same code last March and at that time my dealer replaced the camshaft positioner sensor. The techlink mentioned in the first post says not to replace this, but "Remove the oil filters from the camshaft position actuator solenoid valves". What exactly does this mean? Do they put new oil filters in?
08 Salsa Red Astra XR 5dr 5spd Spt Pkg, Prem. Aud. and Sunroof |
#10 |
Forgot to mention, car sounds like a diesel at idle and I notice there acceleration is a bit sluggish.
#11 |
![]() Join Date: Aug 2011
Have the p0014 code. Can anyone help with a pic or description of the location of the camshaft position actuator solenoid oil filters. Is the removal of these oil filters a simple procedure? thanks
#12 |
2008 Astra XR
I have a check engine light since 2 days and the car lacks of power between 2000 and 4500 rpm.How do we clean those camshaft position actuator solenoid valves filters?
2008 Red Astra XR3 5-speeds Sport Handling Package Premium Audio Package 17's |
#13 |
2008 Astra XR
They just did that repair and they charged me 62$.its not covered by the powertrain warranty.i will call gm canada to know why its not covered by the 160000 km warranty.its a really easy repair to do.Only remove the two cam actuator and remove the 2 orange screen/filters.torque the bolt to 53 inch/pound or 8 newton-meter.20minutes and you are done.
#14 | |
![]() Join Date: May 2010
2008 Astra XR
2003 L-Series 2.2L Sedan
Bertha [2008 F250 S.D.] 4dr|6.4ltr Diesel 350HP|4x2|6ft bed. RED [2008 Sat. Astra XR] 2dr|1.8ltr Ecotec 140hp (will be missed) Oggly [1984 Isuzu Trooper II] 2dr|2.0Ltr G200 89HP|White|4sp manual |
#15 |
2008 Astra XR
Did they covered it under the powertrain warranty or the bumper to bumper 3years60000 km?
#16 |
#17 |
![]() Join Date: Jul 2010
2008 Astra XR
Will they do this repair without the check engine light/codes? My engine is very rattly and has very uneven power output/acceleration... but the check engine light has never come on.
2008 Astra XR 3-Door, Black Sapphire, 4-Speed Auto |
#18 |
![]() ![]() Join Date: Oct 2002
2008 Astra XR
2008 SKY Red Line
#19 |
The code may be set even though you've never seen the CEL light come on. You'll have to either bring it in (taking a chance on paying diagnostic charges in case there are not any codes set) or buy/borrow an OBDC II code reader and see for yourself if there are any codes set.
#20 |
![]() ![]() ![]() Join Date: Nov 2008
2009 Astra XR
My CEL had come on and off, for about a month leading up to last week. I also noticed that the car would stumble sometimes on acceleration, and the near stall, upon press the clutch near a dead stop. So last Friday the light had been on for a week, and I got OnStar to give me the code, which was P000A. Brought it in to the local GM dealer yesterday, and the tech did whatever as per the TSB (replaced cam shaft actuator filters or something, I don't have the work order handy). It was done under warranty, I still have the bumper to bumper, but I assume it would be covered under power-train warranty. It runs a lot smoother now, doesn't hesitate when accelerating through 2500 rpms, and doesn't stutter when I disengage the clutch. Fuel mileage "seems" to be a little better as well, but I'll need to give it more time to find that out for sure.
On a side note, the guy tried to sell me on throttle body cleaning. He tried to tell me that there were also codes stored related to that, and that it was required after 30,000kms, and mine had not been done yet. First of all my car only has 26,0000kms on it. $69 plus tax. I said thanks, but no thanks. He tried to tell me that the CEL might come back on as a result of my refusal. Sheesh. Everything at the dealer was a positive experience until they pulled that little stunt. Anything to make a buck I guess, but it really leaves a sour taste in my mouth. This was City Buick in Toronto, BTW.
2009 Saturn Astra XR3 5-Speed - 86,000KM |
Check engine light on code p000a | HECTOR VAZQUEZ | Astra General | 7 | 02-13-2009 01:14 PM |
97 SW2 Lack of power when hot | klaus | S-Series Tech | 7 | 09-09-2006 04:31 PM |
lack of power problem and sputtering | gypsy35 | S-Series General | 20 | 09-21-2005 10:56 PM |
Lack of power | radioouman | S-Series Tech | 3 | 01-09-2003 07:56 AM |
lack of power | saturn_guy | S-Series Tech | 2 | 05-11-2000 11:15 PM |
