#1 |
![]() Join Date: Jan 2009
2007 ION-2 Sedan
Steering wheel off center GM does not want to fix it because they can't see it according to them after they replaced the steering column and struts. If I make the wheel straight then the car pulls to the right. Also they can’t find the clunk noise when turning the steering wheel. what bs
#2 | |
![]() Quote:
But that isn't the "correct" method. Every steering box or rack & pinion has a natural "center point" designed into it. This point is what you might call "neutral", with anything off a bit to either side being designed to "pull" the vehicle back to this neutral position (when tied in with all of the other angles and forces being transferred to it from the suspension). When an alignment tech installs the heads on the wheels and does his sweep, the machine is sensitive enough to detect it. The alignment is then supposed to be performed around that point, and the steering wheel removed and relocated on its splines if necessary to get it back to "nearly straight". Final tweaking can be done as a toe adjustment to get the steering wheel "perfectly straight", but the box/rack will then be off-center again by a small amount -- which may or may not cause a pull to one side or the other. But to climb back onto the service side of the service counter, I often wonder why a perfectly straight steering wheel is so important. It isn't a protractor. The steering wheel does not dictate what is "straight ahead" -- the driver does (by ignoring the wheel and going by instinct instead).
"That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering." |
#3 | |
![]() Join Date: Apr 2004
2008 Astra XR
![]() Quote:
Rex 2008 Astra XR 5 dr, 5 spd, sport package Black Sapphire If you're going to wave, use all your fingers. |
#4 |
2007 ION-2 Sedan
I had it back at the dealer they could not find that it was not "straight". When I got the car new it was. So I have to bring it back monday becase the GM rep is coming to look at it. They do not want me to go ona ride with them I offered. It is the only GM dealer in my area 60 miles that will work on Saturns.
#5 |
2007 ION-2 Sedan
They are not going to fix the problem! They won't even have me drive with them. I think this is the end for me and GM!
#6 |
![]() Join Date: Apr 2009
Oh man... I am getting a much better treatment at my dealership in Toronto - they wouldn't let me out of the shop unless I was 100% satisifed.
09 Astra XR (manual, 3-door) |
#7 |
Now that is totally unacceptable. It seems that someone needs to be reminded of the true definition of "service". A phone call to GM Canada should get the ball rolling. Every dealer has a CSI (Customer Satisfaction Index) that they try to keep as high as possible, and GM tends to come down hard on the ones that fair poorly. Just be sure to mention to them that the dealership refused your offer to go along with them on a test drive to better explain the problem. You'll probably get a phone call back from your dealer after that.
#8 |
2007 ION-2 Sedan
The problem is i have two other saturn and 95 SL and a 06 Vue. If i report them i will not have anything fixed in any of my cars then. This is the only dealer in my area. So it looks like I will have to pay 100 dollars to get an alignment not at that dealer, but a Dodge/Jeep dealer that i go to for my Jeep. That is for Balance and alignment, most tire store want 69 just for an alignment. If i make make waves about this i might never be able to get my other saturns fixed. See my problem.
#9 |
I can see your point, but I doubt that a dealership will refuse to work on any of your Saturns just because you went over their head for one issue. They might not be think too kindly of you afterwards, but you'd literally have to beat the crap out of the service manager before you'd be banned from a dealership. There are good customers and bad customers, but even the bad ones are entitled to equal service as long as they don't cross the line.
If your Chrysler dealership has the specs for your Astra in their alignment machine, then that's probably your best bet. Or a true "frame/alignment shop". Dealerships have to have up-to-date specs for their own makes, as well as other makes so that they can perform some repairs on their used vehicles and trade-ins. Hopefully those specs are up-to-date as well. Software updates cost a shop money and many smaller shops lag behind a few years because people usually tend to take their new cars back to the dealership while still under warranty. The last shop I worked at (a tire shop) charged over $100 CDN for an alignment and our specs were four years out-of-date. It just wasn't worth it for us to update our software every year or two for the half dozen alignments that we had to turn away each year because the cars were too new. OTOH, I remember a Chrysler dealer not far from us that was so small that they didn't have their own alignment machine and subbed everything out to an actual frame/alignment shop.
#10 |
2007 ION-2 Sedan
They have a machine there old one broke so they are waiting for a new one.
#11 |
![]() Join Date: Mar 2010
if you know alignment specs for your car, you can go pretty much anywhere.
#12 |
2007 ION-2 Sedan
Thank for your help
#13 |
2007 ION-2 Sedan
I droped my other saturn off on tuesday for an appointment on tuesday and they are not going to get to it until friday! I think my next car choice will be a Ford or a Dodge!
#14 |
![]() Join Date: Dec 2009
2008 Astra XR
#15 |
![]() ![]() Join Date: Jun 2010
1992 SL2
Talk to the dealership manager? The manager should just get the front end guy to reset the front toe for you. Did they do a 4 wheel alignment? If its a warranty repair they won't do a four wheel alignment. Rear toe has alot to do with the steering wheel being off center. Maybe you could offer to pay for the rear alignment? $49.99(We charge $109.00 for a four wheel) Where are you located? I'm a Cadillac mechanic for 24 years. It's hard when you work on Buicks-GMC Trucks-SAAB-Oldsmoble(yes we still work in them)Cadillac and Hummer. Now Pontiac's and Saturns show up and we work on them too. If someone comes in with a Pontiac or Saturn with weird noise and we haven't worked on it it can be difficult to find the noise because we don't know the car yet. Here in San Diego they have hired Saturn teams at 2 dealers to do Saturns. I take pride in all the cars I do alignments on the steering wheel is straight. The Owner of the last dealer I worked at liked his steering wheels all very straight. I got good at getting the steering wheels straight. I have 3 Saturns 92sl 97sl 98sc Matt
#16 |
2007 ION-2 Sedan
I had it done at goodyear, It was soo off it was not even funny. I am going back to try to get them to pay for it.
#17 |
1992 SL2
Good job!
Bookmarks |
Upgraded to leather steering wheel; now wheel is off center | kkspeed | S-Series Tech | 8 | 04-16-2008 07:14 AM |
Steering Wheel Off Center | Woody Long | S-Series General | 21 | 04-13-2008 09:51 AM |
Steering wheel not dead center | Isis | S-Series General | 3 | 06-04-2006 09:30 PM |
L Steering Wheel Off Center Fix? | Yankeez | L-Series Tech | 6 | 07-17-2003 11:13 PM |
steering wheel of center | satfanNJ | General Saturn Discussion | 3 | 03-15-2001 02:11 PM |
