#1 |
![]() Join Date: Oct 2008
1997 SC2
i've been doing some looking around and I was wondering. when you bore out the throttle body (please correct me if i'm using the wrong term; i mean: http://www.qksltwo.com/tb.html ) i've read you are supposed to get a slight hp boost. My question is will it increase, decrease, or do nothing to your gas milage?
I purchased a $40 CAI off ebay and i think it gave me a small boost but dropped my milage by about 2 mpg. So will this also drop my milage or what can I expect? Thanks in advance! |
#2 |
You have to feed all of those new ponies, there is no free lunch unless you increase the efficiency of the combustion process.
#3 | |
![]() ![]() Join Date: Jul 2005
1995 SL2
![]() Quote:
Just kidding!!!!
"When you stop to fill up on oil, don't forget to check the gas" 98 SL2 MT 213K+ Daily Driver 38+ mpg 97 SL2 AT 150K Original Owner 95 SL2 MT 220K+ My Saturns have BRASS ones! |
#4 |
1997 SC2
makes sense. thanks
#5 |
![]() Join Date: May 2008
Do the TB mod if you want, and don't worry about 1mpg?? Just go for it, will increase your reaction and maybe 1hp
1998 SC2 - 92' header, Cat-back, CAI, Wires and plugs, Intrax lowering kit, Strut bar, LUK clutch, Just polished, Short shifter & Dojo™ knob Coming up: Meet up on the 25th. |
#6 |
![]() Join Date: Mar 2005
1997 SC2
1995 SW2
skip the porting and get a geo storm throttle body
sixthsphere.com owner 2002 Saturn SC2 - RHD |
#7 |
Yeah, the Storms SOHC TB is larger then ours can be bored to and the DOHC TB is larger still.
The proper way to fix a S-Series automatic is to replace it with a manual |
#8 |
![]() Join Date: Dec 2008
1996 SL2
In all reality unless you are boosting or trying to make some good power, TB isn't going to do much for you. Except increase throttle response.
#9 |
So any metro TB will be a directly swap? Same hoses, same screws and all that? I saw a geo metro when i got the 92 headers on the junkyard. Here are the pics
I'm doing the bore at home, then SRI
#10 |
![]() Join Date: Jan 2009
2000 SC1
thkx for the link very cool
#11 | |
![]() ![]() ![]() Join Date: Feb 2005
1999 SC2
1999 SC1
![]() Quote:
The storm tb will bolt up, the TPS & IAC either plug in or splice in, and the throttle cable requires a custom bracket.
SaturnSeries.net owner |
#12 |
Storm then, sorry
#13 |
1996 SL2
As PurdueGuy said, you will need a custom throttle cable bracket. As the Storm I believe is back farther then out stock location. Or vice versa can't remember exactly.
#14 |
LOL, I was wondering about what kind of performance parts y'all were wanting to pull from a 3 cylinder 1.3 liter engine
![]() I test-drove a Storm when they first came out, and came this close to pulling the trigger on buying one. Kinda glad I didn't, seeing how they seem to have held up over the years. |
#15 |
I'll check the sizes and see what i can do, otherwise i will open up my own, but do it throught the whole TB, not like others do, bore till the butterfly or door, thats not a mod. You need to fully open the ID of the TB to let it better flow
#16 |
1996 SL2
People bore out both sides of the TB to the butterfly plate. You can't bore out around the TB plate because obviously the plate wont fit snug.
#17 |
1999 SC2
1999 SC1
If you remove material around the throttle plate, your car will never idle right again unless you replace it with a larger throttle plate. It also doesn't help to port the throttlebody out on the backside any more than to match the intake manifold.
#18 |
Of course i will not leave the stock plate if i'm doing the full ID bore. And i'm also matching with the intake manifold size. I've done this to both of my friend's civics and they worked good.
#19 |
1994 SL
Are either or both of those both of those direct fit? I have an sohc, and any lil bit will help.
Where the fug is my mirror? ~No Regrets, Just Life Lessons~ I need more speakers 94, SL, 250k+, manual trans, no power anything, sparkplugs, exhaust, CAI, steering wheel, FLUX CAPACITER!!!! |
#20 | |
1999 SC2
1999 SC1
![]() Quote:
Bookmarks |
Throttle sticks - not throttle body - help! | dannysm213 | S-Series Tech | 2 | 12-10-2006 05:20 PM |
throttle body how far? | irondiezl3 | S-Series Tech | 1 | 11-12-2006 10:40 PM |
Throttle body mod | newt | Mods and Performance | 13 | 06-13-2002 06:46 PM |
ground effects / body mod | Elmo | Miscellaneous Tech | 3 | 10-02-2000 07:20 PM |
ground effects / body mod | Elmo | Suggestion Box | 0 | 09-29-2000 04:15 PM |
