![]() Join Date: Feb 2008
I've done the valve body/shaft nut process to no avail. Time to cut the line
before I reel a shark in my row boat and it eats me. I have someone with a 1994 SL1 auto. trans. for a 2.2L motor. Will it swap out with my 2000 1.9L? They blew their motor and got another with the trans. on it and want it gone for $50.00. If not, does anyone want it? What MP6 year range will work. Thank you kindly.... |
Non existant. All s-series have a 1.9L motor. At best with a boring its 2.0L
You need an auto transmission from a '98+ s-series. However you did not post your vitals. So if you have a DOHC then it has to be from a DOHC car If you have a SOHC it has to be from a SOHC car.
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place |
Thank you. The top of the valve cover just says "OHC" so I'll get the number off the trans. Tks again.... Mike
Just noticed in the title - recipient is a 2000 SL1. That means it has an MP6 tranny. According to http://www.differentracing.com/tech_...gearratio.html , gear ratios for the MP6 changed in 1998, so indeed, you need an automatic tranny from a 1998-2002 SL, SL1 or SC1, or 1998-1999 SW1. That 1994 tranny will need to find another home.
Be absolutely certain about the donor tranny's provenance; any S-Series tranny will "fit", that is, it'll bolt up. But because of the gear ratios, only the above models will _work_. |
#5 |
Thank you for the info. Almost all of the wrecking yards/tran. recyclers...
said that 1995 to 2002 would work. I would have been very upset if I had put in the wrong transmission. You are a fine and great person... |
#6 | |
The streets will flow with the blood of all the non-believers!!!! And all those who won't include their vehicles vital information in their posts!!!! |
#7 |
i got trans code 23 on my 93 sl1 auto help | bates | S-Series Tech | 20 | 10-09-2009 12:57 PM |
2000 sl1 auto trans problem | blackeyedpea | S-Series Tech | 11 | 05-10-2008 06:20 PM |
2000 sl1 auto trans problem | blackeyedpea | S-Series General | 2 | 05-08-2008 01:21 PM |
2000 SL2 Auto Trans. Slamming into all gears.....WHY? | daddyo10161 | S-Series Tech | 3 | 05-18-2006 11:42 AM |
2000 SL1 w/ Auto Trans - "Noise" and White Smoke | jonsoini | S-Series General | 0 | 05-11-2005 11:58 AM |
