Old 03-08-2008, 03:48 PM   #1
tacinc1
tacinc1 is on a distinguished road
Default Changed trans. fluid to synthic, only 4.5 qt!
I'm doing the reverse slam fix. I changed the filter/fluid and used syn. fluid
but it only took 4.5 quarts. I found out the TC has old fluid in it. Is there
a way to blow out all 7 quarts? Whats going to happen now that I have
regular trans. fluid mixed with syn. fluid? I have not driven the car, but
have had it in drive for a minute or two.
Thank you for your time and help.
tacinc1 is offline   Reply With Quote
Old 03-08-2008, 09:26 PM   #2
Old95SL2
Old95SL2 is on a distinguished road
1997 SL1
Default Re: Changed trans. fluid to synthic, only 4.5 qt!
Thats normal, it will be fine. If you want to get more of the old out, you fill it, run it around a while, and repeat the drain/refill. I'd consider just leaving it till next 30K change though, it is fine.
Old95SL2 is offline   Reply With Quote
Old 03-09-2008, 09:30 AM   #3
BarnOwl
BarnOwl's Avatar
2000 SW2
There is a way but, I won't recommend it. Years ago my brother had a radiator that leaked into the transmission cooling compartment. We got some friends together, pulled the bottom transmission line at the radiator and put a bucket under it, started the car, and poured new fluid in while the tranny pumped fluid out till it ran clear. It took about 24 quarts. The extra guys were swapping drain buckets and opening cans while this was going on. In case you're wondering, ATF with coolant in it looks like Pepto Bismol.
Old 03-09-2008, 10:25 AM   #4
CA-Legal-Vette
CA-Legal-Vette is on a distinguished road
That's pretty clever! An awful lot cheaper than pulling the transmission apart and cleaning it up.
Oh and I did a transmission fluid change last weekend. 4.5 quarts of fluid.
CA-Legal-Vette is offline   Reply With Quote
Old 03-09-2008, 05:24 PM   #5
Luke
Luke's Avatar
> Fm Barn Owl <
> pulled the bottom transmission line at the radiator and put a bucket under it, started the car, and poured new fluid in while the tranny pumped fluid out till it ran clear. It took about 24 quarts. The extra guys were swapping drain buckets and opening cans while this was going on. <
Tell me we don't have some sharp techs on this forum.........
Luke is offline   Reply With Quote
Overfilled trans Fluid, now TC not lockout. Is Total trans rebuild ahead? 62morgan S-Series Tech 14 02-23-2009 09:30 AM
Using synthetic trans fluid, how many miles till the next fluid change? turbobuick33 S-Series Tech 11 06-14-2007 02:06 PM
Changed Trans Fluid, stickier than before?? Maritime Storm S-Series Tech 6 05-22-2007 06:31 PM
How often should the automatic transmission fluid be changed? Bullet Vue Tech 7 05-24-2006 11:39 PM
Does this mean the tranny fluid was changed? BarnOwl S-Series Tech 8 02-02-2006 02:49 PM
