#1 |
![]() Join Date: Feb 2008
I broke a front wheel lug nut stud trying to remove the tire and could not
get the stud all the way out at any of the 360 degree positions. So, I removed the axle nut and tried to tilt the hub for clearance to no avail. Crap. I removed the brake caliper and realized that now I could remove the broke stud and replaced it. So, just remove the caliper. Reminds me of the saying, "Don't die stupid." |
#2 |
![]() Join Date: Oct 2010
Glad to read that you were able to get the job done even if you ended up doing all that extra work.
I am currently stressing as I have tried to replace my lug stud a few times but have not been successful. For me removing the brake caliper and the rotor on my sl1 does not give me any clearance to insert a luge stud. Is this all you are supposed to have to do because to me it seems as if you need to remove everything but the axle in order to get clearance? I am quite frustrated and would love some input if you have had success. Thanks! |
#3 |
I've never had to remove the caliper to remove the studs. In fact we put longer studs on our old drag car and didnt have to remove the calipers.
Mike -1991 Turbo SL2. 11.809 @ 116.488 mph www.differentracing.com -2001 Limited Edition SC2 (#78) -2001 Chevrolet Suburban -2007 Saturn Aura XR -2011 Rally Yellow Chevrolet Camaro 2SS RS |
#4 |
I've always had to remove the brake caliper to get a broken stud out.
Try tapping the new one in with a small ball peen hammer. I've found that they don't just drop in, but will go in with a little help. |
#5 |
I've had to replace wheel studs on my 94 SL2.
This is how I did mine: Remove the Brakes, Calipers, and Caliper Bridge Use a Pipe Wrench or Heavy Duty C-Clamp to secure the wheel hub. Using a Cold Chisel, tap out the broken wheel studs. With the Wheel Hub in the C-Clamp, position your first open hole for the new stud at the 1 o'clock position. Gently thread the new wheel stud into place. When it clears the wheel hub and the hub secured with Pipe Wrench/C-Clamp take a Lug Nut to pull the rest of the new wheel stud thru the wheel hub until it is firmly in place/position. Then undo the Lugnut and move onto the next wheel stud replacement, then put all of the brake hardware back in place and position the wheel and attach lugnuts. Done. New Wheel studs are $3-$4/piece at your local FLAPS.
Bryan 94SL2 HCE, "Pearl" 99 SL 94SL2 260K Miles 1/15 97SW2 266K Miles 2/15 Always 94SC1 340,501 Miles Org. Engine/Auto Trans 2/97-10/08 Gone 3/12 92SL1 05VUE 91SC |
#6 |
![]() Join Date: Sep 2010
or you could chuck up a 3/16 th's drill bit,
go thru most of the way, chuck up a 3/8 in a milwaukee 1/2 inch jacobs super chuck and you are gone in 60 seconds with the cheap azz steel they use, a little 3o wt on the drill bit so you don't bind, if you are a Fabricator A, you know how to correct for drill drift, everybody pushes up and left, don't forget to vacuum the chips off the living room carpet, |
#7 |
double post - mod delete
#8 | |
![]() Join Date: Jan 2014
1993 SL1
![]() Quote:
"A Different Kind of Car Company" -Saturn Generation 1 motto |
#9 |
The knuckle is the same 91-02 the only difference is the number of and diameter of the splined axle hole in the hub. The method you copied works on all years.
#10 |
![]() ![]() ![]() ![]() Join Date: May 2008
2004 VUE 2.2L
Geez just get a good hammer, pound the old one out, use an old lug nut and impact to "pull" the new one in and seat it. Done. It takes longer to jack the car off the ground than do the job
2006 Toyota Highlander (rare 4 cyl AWD) 2001 Toyota Highlander V6 AWD creampuff Daughter got her own! 2005 Lexus ES330 Dream Ride |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2013
I'll give a contrary opinion... any method that involves a big hammer isn't good for bearings. You may get away with it, but don't be surprised if that bearing goes bad prematurely.
#12 |
+1^^^^You get your choice of stuffed bears on the back top row for the right answer. Do not beat on the hub you will hurt the balls.
#13 |
MechE - I make things! EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard 1998 SL2 (gone, never forgotten) 2005 Volvo S40 T5 AWD 1987 Mercedes 300D 1993 Tracker 4x4 1996 Tracker 4x4 |
#14 |
2004 VUE 2.2L
Haven't hurt anything yet. 40+ years. In theory maybe correct but, if the hub is good you won't hurt it. And if it's marginal even then only "maybe"
Bookmarks |
Broken Lug Stud | RGZ | S-Series General | 2 | 10-03-2008 01:09 PM |
95 Sl2 Front lug nut , contact depth . | udderslate | S-Series Tech | 5 | 04-27-2008 07:49 PM |
Broke stud removing lug bolt??? | BarnOwl | S-Series Tech | 3 | 12-12-2005 09:56 AM |
S series lug stud broke off | cabo5150 | Miscellaneous Tech | 8 | 08-11-2003 09:32 AM |
How to replace wheel lug stud? | ym42 | S-Series Tech | 4 | 07-28-2003 01:47 AM |
