#1 |
![]() Join Date: Oct 2020
1999 SC1
2001 SC1
I did a compression test, the engine was cold, I tested for 10 "cranking noises" the results:
1;90, 2;110-145, 3;121, 4;130 added some oil: 1;100-145-123, 2;110-145, 3;110, 4;145-120 because I was not sure if this was correct (given the inconsistant results, and how far off they were from 180), I cranked it until it stopped on its own 10 times (usually 4-5 "noises"). this was with oil in the cylinders the results: 1;175, 2;189, 3;170-180, 4;180 ![]() How EXACTLY would I get the most accurate readings possible on a compression test? A thread posted in 2003 ![]() I would like to do it correctly next time. ![]() This is on a 1999 SC1 with the SOCH engine, nearly 170000 miles. I can not drive it until it passes emissions, and it will not pass with a "service engine" light. I have gotten a code P0301 for a missfire in cylinder 1, as well as the "service" light with the wrench. The light usually comes on after a few seconds (although sometimes it does not come on until the engine is shut off and restarted), but my OBD2 scanner usually takes a very long time to detect the error code. I have tried changing the spark plugs/wires, ignition coil packs with the plate they attach to (could not figure out how to separate them), fuel injectors, ECTS (with coolant), idle air control, EGR valve, (and cleaned as much out of the holes as I could), and MAP sensor. I also sprayed carburator cleaner around the intake manifold, it did not run any different. Dad said it smells like it is running rich (my nose does not work) Any other ideas? (do not be afraid to tell me it needs an engine, I have a 2001 SOCH with the transmission sitting on a pallet in the garage) ![]()
1997 V6 Mustang coupe 2018-2019(wrecked, airbags went off) 2001 SC1 2020-2021(wrecked, frame was bent) 1999 SC1 2021-now(working progress) |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2013
Did you hold the throttle wide-open while doing these crankings?
Run it for a bit, then take compression again; and be sure the battery is good enough that voltage doesn't drop below 11V while cranking. This time, don't do any of that "adding oil" routine. That is only confusing things. Yes, adding oil can help determine if the rings/bores are worn, but that is rarely the case with these engines because of their oil burning issues. And, if you add too much oil, compression will get falsely raised, possibly even to the point of locking the engine rom turning! PS: Five compression strokes is enough to get full compression on a good cylinder... |
#3 | |
See post 2 in these threads
http://www.saturnfans.com/forums/sho...d.php?t=200832 http://www.saturnfans.com/forums/sho...d.php?t=236763 edit: I read your post again, missed this question Quote:
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#4 |
Your compression numbers, are WAY low...
Regardless if you do a wet or dry compression test... your numbers across all 4 cylinders should read at least 185 or better. The standard PSI rating across all 3 cylinders for the majority of the S-Series run; was 185 on each cylinder. As you may know- these engines were known for oil burning... and the only way to really do *Some* kind of fix for oil burning, is to drill small holes in the pistons to allow for some kind of oil draining. I think you may be chasing your tail on this one; as much as I hate to say that... nothing that you are going to do outside of the engine, is going to bring those compression numbers to a decent working number.
Bryan 94SL2 HCE, "Pearl" 99 SL 94SL2 260K Miles 1/15 97SW2 266K Miles 2/15 Always 94SC1 340,501 Miles Org. Engine/Auto Trans 2/97-10/08 Gone 3/12 92SL1 05VUE 91SC |
#5 |
1999 SC1
2001 SC1
Yes, I had the pedal all the way to the floor.
I do not know if the results for my compression test were accurate, because they are not very consistant, and I may have been doing it wrong. I will record a video later today, and maybe edit numbers counting the "pulses" of noise that I am discribing. If the engine is bad, I have another one that was not misfiring after 181,000 miles (at least, before I crashed the car I pulled it out of).
#6 |
1999 SC1
2001 SC1
If 10 compression cycles is minimum, how would I count the number of compression cycles?
Bookmarks |
How-To: Compression testing w/ engine out of car | ShawnV | How-To Library | 6 | 10-14-2010 11:42 PM |
2001 SOHC P0301 - confusing compression numbers | BobbyBeans | S-Series Tech | 44 | 05-24-2010 11:34 AM |
compression testing results | Amp67 | S-Series Tech | 3 | 05-27-2009 01:54 PM |
Testing Compression in an S-Series | Saturn-Eh! | How-To Library | 20 | 10-13-2005 03:54 PM |
Compression and Leak Down testing. | Red97sc2 | S-Series Tech | 2 | 04-09-2004 02:37 AM |
