#1 |
![]() ![]() ![]() ![]() Join Date: May 2011
All,
Maxi fuses are becoming harder and harder to find. I suggest you keep a spare or two in the glove box… 50 amp https://www.rockauto.com/en/parts/bu...AX50,fuse,2676 30 amp https://www.rockauto.com/en/parts/bu...AX50,fuse,2676
2002 Silver SL2, manual, 5th gear swap (.605), 80,000 miles, black badges, 205/60R15 "H" rated tires, 5mm spacers rear... Pennzoil Maximum Power 0W-30, Champion COS3600... NGK BKR6E-11 spark plugs |
#2 |
People buy those? What a waste of money, though it is hard to argue with $0.90 for one.
Almost every parts car I had I stripped it for the fuse's along with other easy to reuse/repurpose parts before scrapping. All the Fords and GM's I've worked on use them as well so I assume they're still "littering" junkyards across the country. Trucks in general, 3/4t's specifically, tend to have the higher rated fuses and more of them. |
#3 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2015
I have a pretty fair collection of em - just in the parts cars out behind the barn...
Currently owned 93 SC2 M(anual) 96 SC2 M 98 SL2 A(uto) 99 SC2 A 01 SC2 A 01 SC2 M 02 SC2 M 02 SL2 A 02 SL2 M parts 2 94 SC2 parted out 2 96 SC2 98 SC2 - rusty frame minus engine. 98 SL2 |
#4 |
![]() ![]() ![]() Join Date: Oct 2017
1994 SL2
Darn!
Just one more thing I forgot to pick up when I was at the wrecking yard last week. Odd thing is, I just had to replace the 10 Amp fuse that powers my Hazard Flashers and Bright Lights Indicator. And I had to dig around for a fuse for it! Luckily there was a spare in the underhood fuse block. I have no idea what blew that fuse or when it actually blew (within the last 3-4 days). Preston |
#5 |
Do our S-Series Saturns use that 50MAX fuse? According to RockAuto.com they are not listed when I search for parts that fit my 97 wagon.
I was going to purchase 4 fuses but it was going to cost $6.99 to ship them.
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg • 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg • 1994 SL1 new traded • 1992 SL2 new traded for above * 1986 Yamaha ce50 Jog -100 mpg |
#6 |
Note sure the first and second gen cars used the 50...
Another kit to get is the Busmann Easy ID kit, has seven each of 5, 10, 15, 20, 25, and 30 amp light up fuses.. https://www.eaton.com/us/en-us/skuPage.ATC-ID-SK.html https://www.rockauto.com/en/parts/bu...IDSK,fuse,2676 Note that there are spare ATC fuses in the fusebox, but not Maxi's
Bookmarks |
Fuses... | mattwithcats | S-Series Mods | 0 | 01-26-2019 09:13 PM |
97 Sl2 keeps blowing ign 3 30a Maxi fuse | jaredthefail | S-Series General | 1 | 03-28-2015 08:10 PM |
Where are the Fuses??? | grambo | Outlook General | 9 | 02-27-2007 09:42 AM |
fuses | msbplane | Ion Mods | 5 | 09-26-2006 08:24 PM |
Fuses ? | Crypto1969 | L-Series General | 2 | 03-06-2006 11:35 PM |
