Old 11-08-2005, 09:08 AM   #1
PitchBlackSC2
PitchBlackSC2 is on a distinguished road
PitchBlackSC2's Avatar
Default Spark Plug Wire #1...
...seems to have a burn on it or something. There is a small area on the wire, near the boot, that is darkened and even sticky when the car is hot. Should I be alarmed? FYI The plugs are AC delco and the wires are Bosch.
PitchBlackSC2 is offline   Reply With Quote
Old 11-08-2005, 10:48 AM   #2
Luke
Luke's Avatar
Default Re: Spark Plug Wire #1...
First check the overhead hood corresponding area, to determine if the wire had been rubbing up against the black hood sound blanket.
Luke is offline   Reply With Quote
Spark plug wire clip sferguson S-Series Tech 3 05-19-2007 04:38 PM
Spark Plug Wire Help awhat? S-Series Tech 6 04-24-2007 10:20 PM
ignition wire/spark plug wire - resistance/ohms Heartbeat - '95 SL2 S-Series Tech 3 10-17-2005 02:09 PM
Spark Plug Wire Help... Rob1998SL2 Mods and Performance 8 10-16-2003 03:09 PM
spark plug wire boots dohc 97 Miscellaneous Tech 5 04-30-2002 10:24 AM
