Old 05-24-2015, 11:37 AM   #1
SL2nitsua
SL2nitsua has a spectacular aura aboutSL2nitsua has a spectacular aura about
Default stripped the hole for the valve cover bolt...
anyone know how to fix this dirt cheap? need it fixed today but being that its sunday, every auto store in town is closed.
SL2nitsua is offline   Reply With Quote
Old 05-24-2015, 11:51 AM   #2
Default Re: stripped the hole for the valve cover bolt...
A 6mm X 1.0mm helicoil kit. You will not need to drill the stripped hole, just tap it out and insert helicoil. Be sure to get the chips out several times while tapping it out. You Tube has videos. Do not drill it out or it will fail! Auto parts store has them. I have no suggestion for them all being closed though.
Old 05-24-2015, 01:09 PM   #3
SL2nitsua
my friend had a brand new helicoil kit laying around and i went and bought a tap and die set just in case. he went to state in FFA comps for tap and die so i asked him to do it for me haha i havent done tap and die since my freshmen year so its been a bit. he is on his way now and we will see what we can do! thanks OldNuc!
Old 05-24-2015, 02:54 PM   #4
Use the special size Helicoil tap and do not drill it out or it will be oversized. Make a mistake and you will have potentially trashed the head, or generated a trip to a real good machine shop with the head.
Just an 'Oh, by the way'. Those cover bolts are all shoulder bolts and they will only compress the gasket so far and when they quit turning then quit tightening or they break or strip out. You can install them with a nut driver and you will be a bout 1 turn from contact tight. torque wrench recommended. They pull tight at under 80in-lb.
Old 05-24-2015, 04:44 PM   #5
SL2nitsua
got it all done! just need to wait for the gasket maker to dry and i will test it out! Thanks for the advice! that helicoil kit made short work of it and worked perfectly! i got it to where it started getting tight and did maybe 1/8th of a turn then didnt touch it after. i will get a torque wrench on it after the gasket dries some. what is torque specs for these?
Old 05-24-2015, 05:08 PM   #6
Book is 89in-lb and I use 80-84in-lb as I don't like breaking them off. It is very difficult to find a 1/4" drive torque wrench that is affordable and accurate in that range.
Stripped (Torx) Cam Cover Bolt Fixed Baron5867 S-Series Tech 7 08-02-2015 10:08 PM
Valve bolt hole stripped? bushkanaka86 S-Series Tech 7 03-17-2014 11:09 PM
94 SL1 - Stripped Valve Cover Bolt Hole MikesterH S-Series Tech 11 10-28-2010 03:42 PM
Stripped the threading (female end) on EGR mounting bolt hole jk3006 S-Series Tech 31 02-27-2010 08:23 PM
Fixing a stripped cam cover bolt? turbobuick33 S-Series Tech 9 08-18-2007 10:43 AM
