Old 11-04-2005, 08:07 PM   #1
kudude
kudude is on a distinguished road
Default help w/ sc2 clutch replacement
Hello all,
I'm new to the forums and this is my first post. I've searched around a bit and can't seem to find an answer to my question. I've agreed to replace the clutch in my roommates 95 sc2 as sort of a favor/break from graduate school.
I've replaced clutches in
92 mitsu 3000gt
94 nissan sentra
91 ford ranger
92 chevy cavalier
Now, the question I have for this vehicle: i read in a chilton manual that I need to remove the engine, not the transmission to get to the clutch. ARE THEY SERIOUS??? I think i should be able to do it by removing the halfshafts, a bunch of other junk and then sliding the tranny out. Is that right?
Thanks in advance for the help.
jesse
kudude is offline   Reply With Quote
Old 11-04-2005, 08:12 PM   #2
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
Default Re: help w/ sc2 clutch replacement
Originally Posted by kudude
Hello all,
92 mitsu 3000gt
94 nissan sentra
91 ford ranger
92 chevy cavalier
jesse
You cant get the tranny out without taking the cradle out. And you cant get the engine out forom the top unless you pull it all.
Carmen
1998 2.4L swapped Plymouth neon is my ride.
bigc791 is offline   Reply With Quote
Old 11-04-2005, 08:33 PM   #3
JerryHughes
JerryHughes's Avatar
1997 SL
Welcome to the board. From what I've read on this site, you don't have to pull the engine but I don't know anything about a job like this. Search the "How To" section for other posts on this subject and you will get all sorts of information. Good luck,
Jerry
Old 11-04-2005, 08:41 PM   #4
stu
stu is on a distinguished road
1997 SW2
Looking for this?
http://www.saturnfans.com/forums/showthread.php?t=29795
stu is offline   Reply With Quote
Old 11-04-2005, 10:14 PM   #5
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Carmen
This post is full of misinformation.....The tranny doesn't have to come out to replace the clutch. You most certainly CAN however remove the tranny without removing the cradle. You also can get just the engine out the top and leave the tranny right where it is....though that is also unnecessary.
Take out the 2 cradle bolts on the tranny side of the frame. Undo the engine to tranny moutning bolts and the tranny mounts, yank the halfshafts and slide the tranny over. There is more than enough room to R+R the clutch components without removing the engine OR the tranny.
SaturnTech is offline   Reply With Quote
Old 11-04-2005, 11:00 PM   #6
eljefino
eljefino's Avatar
1995 SW1
Jesse you are right and don't give it a second thought.
The only place to be careful is the clutch slave cylinder; the nylon hose going into it is fragile. Push the cylinder in and rotate it 1/6 turn counter clockwise to free it then tape it to the upper radiator hose to keep it out of the way. Dont use the nylon pipe for leverage as tempting as it might seem!
You'll have to lose the air intake, battery, tray, inner fender shields... all pretty easy with common hand tools. 18mm for the lower ball joint.
Old 11-05-2005, 12:04 AM   #7
tabb
tabb is on a distinguished road
If you remove the shift tower and the inner fender plastic covers, you can slide the tranny into the space between the subframe and upper frame member. The tranny will sit nicely into the pocket and you won't have to remove any subframe bolts....
tabb is offline   Reply With Quote
Old 11-05-2005, 05:41 AM   #8
kudude
thanks for all the responses guys, I'm impressed with these boards already. The roommate whose car I'm working on is all about the technology, etc so I'll see if i can get him to take some pictures and i'll do a write up from the perspective of someone who doesn't really know much about these cars. thanks again, i'm sure i'll have some questions as I go
jesse
Old 11-06-2005, 01:15 AM   #9
kudude
Hey,
So i've got a new problem. I took everything apart today and (just like you guys said) was able to get myself the six inches of clearance or so that I needed to change the clutch without removing the engine (or really the transmission).
Now I have a problem. The friction plate is not nearly as worn as I'd expected but there is definitely some oil on it, and there is a fair amount of oil in the bell housing. I've heard of rear main seals giving this trouble on other cars I've worked on, and from the threads I've read on this board, I'm hoping that's the problem with this one.
Once I remove the flywheel, is it going to be obvious to me how to replace the seal? I know I need to be careful to seat it correctly, but beyond that I have no idea of what's going on. Also, is it high enough up that I don't need to worry about draining the engine oil? seems to be far enough in the air that it wouldn't matter.
Also, how do i know if it's the fated "quill bearing" that i keep reading about here on the boards. Sounds like that requires a bit of a tranny rebuild, something which I'm certainly not up for....
Thanks again in advance for all the help
jesse
Old 11-15-2005, 06:39 PM   #10
kudude
So, now i have something interesting going on.
The car died while i was driving it. I noticed the speedo and tach were at zero, so i thought maybe i didn't plug a sensor in well and it had come out. Then the whole car stalled out and stopped. Turning the key give no result, so I think the battery is dead. Seems to me like it might be a bad/disconnected alternator. it allowed the battery to run down while not charging it. What do you guys think?
thanks again
Old 11-15-2005, 06:58 PM   #11
JerryHughes
1997 SL
thanks again
My car wouldn't start or turn over or nothing until I replaced the battery. When these Saturn's die, they die, when it involves the battery. I'd have the alternator checked out---at least the connections first. Good luck,
Jerry
Old 11-15-2005, 11:16 PM   #12
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
what would be a good clutch kit to go with?
turbobuick33 is offline   Reply With Quote
Old 11-15-2005, 11:54 PM   #13
kudude
I just bought a stock clutch from Kragen for $130. It'll work fine if I don't try to do any work on the engine
jesse
Old 11-16-2005, 12:50 AM   #14
bigc791
bigc791's Avatar
1994 SL1
lots of good ideas. im gonna have to try them maybe i can make alittle more money on the next clutch i do at work. Thanks guys. As far as my original post goes thats they way the book says it and i never tried any other way.
Carmen
Old 11-16-2005, 12:55 AM   #15
bigc791
bigc791's Avatar
1994 SL1
As far as the car dieing and not restarting check the 2 big ground cables that goto the bellhousing if left loose thec ar will act funny.
Carmen
Old 11-16-2005, 08:04 AM   #16
BarnOwl
BarnOwl's Avatar
LUK is OEM which seem to hold up pretty well. I've seen some others that recommend Valeo. Both can be had on Ebay at a reasonable price.
Old 11-16-2005, 12:37 PM   #17
S3aturnR
S3aturnR's Avatar
1999 SL1
Hello all,
92 mitsu 3000gt
94 nissan sentra
91 ford ranger
92 chevy cavalier
jesse
i removed my tranny last year and it wasn't difficult, just time consuming. i took the hood off, supported the engine from the rafters in the garage, removed tires, axles, exhaust downpipe and cat, supported radiator and steering rack, removed engine cradle and then removed the tranny. you can easily get to the flywheel and clutch from there.
good luck!
s3aturnr
Old 11-16-2005, 10:03 PM   #18
amazinghl
You're suppose to replace the rear seal whenever you have the engine and tranny apart. It is a $10 item with 2 - 3 hrs of labor.
00 Insight 72mpg
Old 11-16-2005, 10:22 PM   #19
kudude
I've read that if it's not leaking, don't mess with it. it's easy to seat incorrectly then you're guaranteed to have a problem costing you way more than $10.
Old 11-16-2005, 11:32 PM   #20
amazinghl
You do know what a seal looks like, right? I'll have to try really hard to seat a seal incorrectly.
00 Insight 72mpg
Clutch replacement bigbfarm S-Series Tech 15 07-14-2009 11:58 AM
Clutch Replacement? sindian S-Series Tech 12 03-31-2009 12:43 AM
A/C Clutch replacement Aztek_SC2 S-Series General 6 12-23-2005 01:15 PM
Clutch Replacement ssicarman How-To Library 15 07-11-2004 11:06 PM
1992 sc2 clutch replacement jbadler S-Series Tech 4 02-05-2004 05:51 PM
