Old 10-25-2001, 11:50 PM   #1
Plastic Gravity
Guest
Posts: n/a
Default Radio POP sound
Hi guys,
I need some help with a radio gremlin that has surfaced in the last two weeks...
The radio will occasionally make a loud pop sound thru the speakers, and sometimes the radio will go silent for a few seconds or the volume will drop off. After I noticed that tapping the bezel will bring it back, I began to wonder if something has come loose inside the unit itself???
I have the CD-EQ am/fm job in a 92 Coupe...anybody got any ideas what to look for? If I pull the unit, are there any components inside notorious for coming loose?
Help!
-Mark
Old 10-26-2001, 03:11 AM   #2
Heartbeat - '95 SL2
Heartbeat - '95 SL2 is on a distinguished road
Heartbeat - '95 SL2's Avatar
Default
Hey Mark, the radio problem probably stems from your hack wiring job jumping the 2 popup headlight motors together, LOL
The popping sound and subsequent volume changes sounds like a short in the amplifier section of the unit. Since radios today are solid state, it's probably less likely that something has come loose on a circuit board, but that it's a bad transistor, resistor, capacitor, etc. -- I've been told that these parts can become intermittent, without dying altogether. I have a similar problem with my home theater receiver, but it's with only the left channel.
You could pull the unit to be sure the harness plug is secure, but I doubt that's it. Since your car is a '92, the unit has probably just seen it's usable life, and it's time to upgrade.
Check this thread out. Maybe RobK can cut you a deal on a factory unit for a 92, or maybe the 93 is the same unit:
http://www.saturnfans.com/forums/sho...&threadid=5858
Heartbeat - '95 SL2 is offline
Rear wheel pop sound orange57 Vue Tech 19 10-20-2010 12:22 AM
2004 VUE - Pop sound? Bowmey Vue Tech 0 07-11-2009 03:51 PM
Pop sound going from forward to Reverse-what is it? Reliabilityman S-Series General 2 03-11-2008 08:58 PM
Radio Sound Dips 62sunbeam Relay General 5 09-18-2005 11:02 AM
Bang/Pop Sound mas S-Series Tech 3 12-17-2004 07:05 AM
