Old 03-17-2005, 07:00 PM   #1
ladyk899
ladyk899 is on a distinguished road
Mad 97' saturn sl2 won't make a sound
i have a 97' saturn sl2 that won't make a sound, i turn the key and the only thing that happens is that the dashboard lights ,the interior lights,and the radio comes on but the car won't start. somone says it might be the neutral switch does anyone have any other ideas as to what it could be? also can someone tell me where to find the neutral swich in this saturn the gear shift is in the floor, this is not a stick shift.please someone help me i'm currently with out a means of transportation because of this problem.
ladyk899 is offline
Old 03-18-2005, 01:20 AM   #2
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
Default Re: 97' saturn sl2 won't make a sound
Others may be of greater help but here's a quick reply...
Have you tried starting it in both Park and Neutral? Many cars will start in either...I have sticks on my cars so I don't know for sure on Saturns.
You may want to check your battery terminals. Just remove the connections from the battery and clean them with a wire brush, steel wool, etc., and reattach to the battery. (Use caution when removing the wires from the battery.)
These would be the two easiest things to check. There are some ignition fuses that may be part of the problem but someone else who's experienced it may be of better assistance.
jambra1 is offline
Old 03-18-2005, 01:43 AM   #3
JDub99SL2
JDub99SL2 is on a distinguished road
It makes no attempt to crank whatsoever?
Have you tried jump starting it?
JDub99SL2 is offline
Old 03-19-2005, 10:21 AM   #4
ladyk899
yes, the terminalsare brand new as well as the battery, my husband checked all the fuses. he tried to start it in park and in neutral, someone told him it sounds like the neutral switch is gone can you tell him where to find it in this car it is an automatic.they say it gone because sometimes it gets hung up when you shift the gear down from park. please, please somebody help me get my baby going again!!!!!!!!
ladyk899 is offline
Old 03-19-2005, 11:03 AM   #5
Razorbak
Razorbak's Avatar
The Park/Neutral Position (PNP) switch is mounted on the rear driver's side of the transaxle case. You can see it by removing the left front wheel and plastic splash shield inside the fender well. It's mounted right above the left drive axle. It is mounted with two bolts, and looks like a geisha fan, with two electrical connectors coming off the passenger's side of the switch.
Be careful with removal and installation, or you might damage the internals of the switch. Proper installation requires adjustment, too, so if you can get the started, you might want to take it down to the dealer to get it fine-tuned.
Razorbak is offline
Old 03-19-2005, 04:38 PM   #6
sierrap615
sierrap615's Avatar
it may also be a bad starter, if you have a test light, crawl under the car and find the tiny wire (should be purple, maybe yellow) on the starter. if when the key is turned the start you don't have power there, then the switch is the most likely culprit, if you do have power, bench test the starter.
sierrap615 is offline
oil leak 97' sl2 rmh2_1 S-Series Tech 9 10-01-2015 11:52 AM
97' SL2 Idle Question SinCitySaturn S-Series General 3 01-05-2009 06:12 PM
97' saturn sl2 won't make a sound ladyk899 S-Series General 2 03-17-2005 08:13 PM
97' sl2 won't start ladyk899 S-Series General 15 03-08-2005 01:12 AM
anyone make an airbag cover for the 93 saturn SL2 ? pjhead S-Series Mods 6 02-27-2005 12:20 PM
