Old 09-01-2017, 09:48 AM   #1
WrightMan
WrightMan is on a distinguished road
2004 ION-2 Sedan
Happy 2004 DIY Cold Air Intake
I just picked up a 2004 Saturn Ion which I think is a level 3 since it has the sun roof, key less entry, power windows, aluminum rims, and everything but no white gauges. The first thing I plan on doing is a CAI but would rather not pay over $200 for one. Does anyone have any suggestions on how to make one for my year? I was thinking about cutting out part of the air box and adding a gasket material to the right side to prevent hot air from the engine. The tube is oddly shaped oval though.
Any tips would be appreciated for this or any other items I should be doing with this car. Next I was looking for a larger TB but have not seen any for this. Otherwise I might just do a port and polish.
Thanks!
2004 Saturn Ion AEM CAI, Aftermarket Head and Taillights, ZZP 2.5" Cat and Custom 2.5" Complete Exhaust
2000 F150 Off-Road 3" Duals and K&N Intake SCT Livewire Tuner
2013 Escape 2.0T AWD CAI
WrightMan is offline   Reply With Quote
Old 09-16-2017, 10:52 PM   #2
NoDisassemble#5
NoDisassemble#5 is a glorious beacon of lightNoDisassemble#5 is a glorious beacon of lightNoDisassemble#5 is a glorious beacon of lightNoDisassemble#5 is a glorious beacon of lightNoDisassemble#5 is a glorious beacon of light
2004 ION-3 Quad Coupe
Default Re: 2004 DIY Cold Air Intake
Don't waste your money. CAI is just for looks. Check out Mighty Car Mods myth bust on this subject. It not only provides zero improvement to your horse power, but it takes away a small fraction. You're more efficient with your factory air box. If you're going for looks grab a can of engine paint ($7) and clean + shoot your air box. Good luck
NoDisassemble#5 is offline   Reply With Quote
Old 12-03-2018, 11:30 PM   #3
Satuneez
Satuneez is on a distinguished road
Did you push through with the CAI?
Satuneez is offline   Reply With Quote
Old 12-04-2018, 10:44 AM   #4
WrightMan
2004 ION-2 Sedan
I ended up making one but it doesn't look that great but over winter I am planning on making a new air box out of stainless steel sheet metal and putting that around the AEM CAI to protect it from the engine bay. I decided to just buy the CAI since the piping I made doesn't look as good but wanted something to block the air from the engine like the systems I have on my other vehicles from K&N. Still debating on if I want to do ceramic coating or keep it as bare stainless steel and am planning on using a decent gauge kitchen grade stainless that my brother can get from his work as scrap pieces. Stainless steel dissipates heat well and should provide a decent shield on it's own but the ceramic coating would add to that and give it a painted look that I can match to the valve cover which I am planning on having redone when I replace the head. Initially I wasn't sure how long term I would be keeping the car which is why I was going to limit my spending on it but since I was forced to sell my built up crown vic this is going to be my new project car to build up.
Old 12-08-2018, 04:37 AM   #5
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
I'm working on increasing the breathing capacity of the stock airbox instead of doing an exposed filter element and having to try and isolate it from the engine bay... I figure that since the airbox pulls air at close to ambient air temp, it is already a fairly efficient CAI, but I found that it's lacking in airflow potential in stock form...
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(FY1 swap), 178K
Too many mods to list in sig...
“Stock” is nowhere in my vocabulary...
19boneatock88 is offline   Reply With Quote
2004 Vue Manual Tran Shuddering on Cold Start in Cold Weather sixstringmonk Vue Tech 5 02-20-2012 08:28 PM
2004 L300 V6 Wagon - Cold Air Intake FLOW22 L-Series General 0 09-24-2006 06:38 AM
Cold air intake removing stock air intake acwild S-Series Mods 2 03-26-2006 01:18 PM
FS: AEM Cold Air Intake for 2003-2004 Ion jmettee Classifieds 1 09-02-2005 12:02 PM
2004 V6 Cold Air Intake? KJB Vue General 10 12-24-2003 01:02 PM
