Old 06-23-2014, 11:00 AM   #1
erik@howes
erik@howes is on a distinguished road
2007 AURA XE
Default p0430 catalyst efficiency low bank 2
Just had this code come up on my 07 XE with 102,500 miles on her. I am thinking of just replacing the downstream o2 sensor first before worrying about the catalytic converter. Anyone else run into this similar situation? The o2 sensor there looks like it is a tight area and I have rather large hands... Not looking forward to some knuckle bashing - and that may not even be it. Other than that, the car is still running pretty good. Hope to have her for another few years.
erik@howes is offline   Reply With Quote
Old 06-23-2014, 02:06 PM   #2
SL19302
SL19302's Avatar
2002 SL1
Default Re: p0430 catalyst efficiency low bank 2
If you have a scan tool thats capable of displaying live data then you can look at the o2 Sensors function, The downstream sensor should switch alot slower and be more stable then the upstream, If the downstream readings appear like the upstream ones then the sensors doing its job and telling the computer your converter is tired.
CHECK YOUR OIL!
p0421 - WARM UP CATALYST LOW EFFICIENCY BANK 1 hufhouse L-Series Tech 2 08-18-2014 11:21 PM
Catalyst efficiency? Good cat or bad cat? 38TransAM S-Series General 0 03-05-2014 11:33 AM
Catalyst under efficiency -- new catcon? Do it myself? vtbirch L-Series Tech 2 10-05-2013 12:24 AM
P0420 Catalyst System Low Efficiency xcfmx S-Series Tech 7 01-12-2005 04:34 AM
Code P0430 TedL Miscellaneous Tech 6 08-02-2004 07:04 AM
