Old 08-29-2013, 09:28 PM   #1
TravelerL300
TravelerL300 is on a distinguished road
2001 L-Series 3.0L Sedan
Default 2001 Saturn L300 Rear Brake Calipers - Phenolic or Metal?
I am going to replace brake pads, rotors, calipers and brake hardware on my 2001 L300 this weekend. When I go to purchase calipers, I find that two different kinds are offered. There is the caliper with phenolic (non-metallic) pistons and the one with metal pistons.
Since I purchased this car used, I don't know which type was the original equipment. I would like to use original equipment products. So far, I bought Wagner semi-metallic pads and Wagner rotors.
Which calipers were original equipment for this car? Thanks for the help.
TravelerL300 is offline   Reply With Quote
Old 08-29-2013, 11:14 PM   #2
Default Re: 2001 Saturn L300 Rear Brake Calipers - Phenolic or Metal?
Good question!? I didn't know there were two materials used for pistons. I do not know which is original. One site's info does explain it;
Are steel pistons better than phenolic, which are plastic?
Phenolic pistons have an advantage over steel pistons;
  • Phenolic pistons do not rust
  • Phenolic pistons maintain original size regardless of age. They are not affected by heat or moisture in the brake system
  • Phenolic pistons do not transfer heat to the brake fluid
  • Phenolic pistons are lighter than steel
  • Phenolic pistons are fuel efficient and noise dampening
Old 08-29-2013, 11:35 PM   #3
pierrot
pierrot's Avatar
I've used Wagner's Thermoquiet line of pads twice on my car and am very happy with them. I would recommend against using their price line set of pads (QuickStop, or ProSolution). What has happened to the calipers which warrants their replacement?
356K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weakened military; increased terrorism; an emboldened RED CHINA. Sadly, B & H are proving me correct...too bad.
Old 08-30-2013, 09:59 AM   #4
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
The OEM calipers have steel pistons, but that doesn't mean you have to stay with steel, and the phenolic pistons seem to offer some advantages.
Jerry N
Groucho Marx
Old 08-30-2013, 12:11 PM   #5
TravelerL300
Thanks for all responses.
The car is in very good condition but it sat for a long time before I bought it. The piston seals are cracked and one of the bushings popped out when I removed the caliper. I would just rebuild the caliper but for a few more dollars, I prefer to just put everything back new.
S3, how did you confirm the OE piston caliper material? I couldn't find this info anywhere.
Old 08-30-2013, 07:15 PM   #6
TurboZutek
TurboZutek is just really niceTurboZutek is just really niceTurboZutek is just really niceTurboZutek is just really nice
TurboZutek's Avatar
2003 L-Series 2.2L Sedan
I go with the 'if it's cheap then it's on our cars' rule. So figure out the price of Phen Vs Steel and you'll have your answer!
Chris...
TurboZutek is offline   Reply With Quote
Old 08-30-2013, 07:58 PM   #7
Old 08-30-2013, 08:08 PM   #8
Frostman
Frostman will become famous soon enoughFrostman will become famous soon enough
2002 L-Series 2.2L Wagon
1993 SL1
Happy someone questioned this. I was never able to figure it out the why and what of it all, but after seeing some advantages, I think I know what I will go with the time comes to change... and it may be soon
Frostman is offline   Reply With Quote
Old 08-30-2013, 09:14 PM   #9
TravelerL300
Well, I ended up buying the calipers with phenolic pistons. I believe that phenolic was the original material but I'm not sure. I called a Chevrolet dealer, gave him my VIN and asked the question. He said that he had no way to confirm. All he could do was quote me a price of $360 each with a delivery time of five days! Mercy!!
I like to buy my parts at O'Reilly Auto and I paid $59.99 each with a $25 refundable core charge and lifetime warranty. They say I can wear the parts out over the next several years and return them for free replacements. I don't even need to keep my receipt because they have my name and phone number on file. I'm keeping my receipts any way.
The metal piston calipers were $69.99 for the left rear and $82.99 for the right rear. That's the Saab/Saturn asymetrical design. The phenolics cost a bit less money but it's not enough to break the deal when it comes to something as important as brakes. Every other vehicle I have owned were full sized cars and trucks and they had metal caliper pistons. Being built for fuel efficiency and light weight, I think the Saturn probably came with phenolic brake caliper pistons.
The other reason I think so is because the metal versions were special order at most stores I checked while the phenolics were in stock.
Another reason is that I found that Wagner and Bosch were the OE supplier of brake systems to this car. Wagner offers only the phenolic version in a loaded caliper, that is, a caliper with brake pads pre-installed.
Alas, I will install the phenolic units, the only difference being the piston material. The iron casting and seals are the same in each case. I might see some improvement in corrosion resistance but some say the phenolics don't last as long in a car that does heavy towing, racing and other abusive driving scenarios. I can believe that but this car is just a gas-saving commuter so I expect good results with with phenolic.
If there are any issues, I can return them under the lifetime warranty. I will report my findings after doing the installation this weekend and I will update this thread if any problems surface later.
Old 08-31-2013, 12:31 PM   #10
TurboZutek
TurboZutek's Avatar
Nice work TravelerL300!
Rear passenger e-brake stuck after not even using it on 2001 Saturn L200 jkbowen L-Series Tech 26 04-22-2014 11:55 PM
Rear disk brake calipers-Preventative maintenance? MikeH S-Series Tech 1 04-20-2008 05:05 PM
rear brake calipers sl2 1993 capttoghog L-Series Tech 1 07-30-2007 12:35 PM
How Do I Adjust Rear E-brake On L300 Calipers? vitomacdoc L-Series General 2 01-15-2005 09:12 PM
Rear brake calipers Rozzwell S-Series General 5 11-23-2004 02:49 PM
