Old 01-03-2009, 09:52 PM   #1
nevets
nevets is on a distinguished road
Default Code p0128
I have a 2002 SL2 and the service engine soon light came on. I had it tested and the mechanic said the Coolant Temperature Sensor should be changed. Is this right for code p0128? (That's what was on the invoice)
nevets is offline   Reply With Quote
Old 01-03-2009, 11:26 PM   #2
Cheyne
Cheyne has a spectacular aura aboutCheyne has a spectacular aura about
2000 SL2
Default Re: Code p0128
2002 has the brass sensor. They usually don't cause a problem, but yours could have failed.
P0128 = Coolant Thermostat (coolant below normal temp range)
Did they replace the thermostat also? What does the temp gauge read now while driving down the road?
If the code is gone and the temp gauge is reading around 3/8, you should be good to go.
Old 01-03-2009, 11:48 PM   #3
What that code is telling you is that the engine was still cold according to the ECTS after the PCM decided it had adequate time to warm up. The problem could be eiter a bad ECTS or a failed thermostat. How long does it take for the engine to warm up? Does the temperature gauge come to 3/8 or a bit above is a short time? If the gauge gets up to 3/8 or a bit above then its probably a tired thermostat and you need a new one.
This link will provide mor details of this code.
http://www.hotrodlane.cc/New%20LS%20...TC%20P0128.htm
showing code 1 of 1 ..............P0128!!!! rayzur9 Vue Tech 25 01-20-2012 10:33 AM
2003 v6 Vue p0128 code majacoby Vue Tech 26 12-02-2010 08:16 PM
Code P0128 Low Coolant Temp 1saxman Vue Tech 17 12-29-2009 11:53 PM
03 Vue throwing code P0128 mattwiant Vue Tech 12 12-15-2009 09:10 PM
P0128 code issue bubba1ton S-Series General 7 05-17-2006 04:25 AM
