Old 06-09-2008, 04:20 PM   #1
saturnd00d
saturnd00d will become famous soon enough
saturnd00d's Avatar
2008 VUE 2.4L
Default Experimented with airflow a bit...
So on the weekend I removed the intake resonator from the vue, along with the foglight cover from the passenger side as well. The intake resonator is in 3 sections, and it the biggest waste of plastic on this vehicle, as it is on every vehicle. So now there is a 4" hole on the front of the air box. As well, removing the plastic foglight cover allows air to be directed into the engine compartment. This makes for slightly more cooling as well.
Driving it all yesterday and today, the engine does have a throatier soound to it, but even more important is a slight improvement in mileage. This is only temporary as I'm currently experimenting with replacing the airbox altogether for a better power increase.
And before anyone chimes in and says that I should have got the V6 if I wanted more power, I'm actually only increasing airflow to improve my mileage. It worked well for my ION (although I was into speed more at that time) and I'm sure it'll work well for the Vue, if even for a different purpose.
___________________________________
http://www.cardomain.com/id/saturnd00d
saturnd00d is offline   Reply With Quote
Old 06-09-2008, 11:57 PM   #2
sparky741
sparky741 is on a distinguished road
2008 VUE 2.4L
2004 ION-2 Sedan
Default Re: Experimented with airflow a bit...
Would you be able to provide more detail as to your procedure for "debonging" your Vue? I'm interested in doing this as well.
sparky741 is offline   Reply With Quote
Old 06-10-2008, 07:32 AM   #3
saturnd00d
saturnd00d's Avatar
2008 VUE 2.4L
There are 3 bolts that hold the bottom piece of the bong. It is easiest to remove the passenger headlight to do all this, as it's right in front of you. Basically the first part is connected (clipped) to the airbox. You'll have to remove the airbox lid and filter to unclip the bong piece from the inside.
After the first piece is out, you can wiggle the second piece out via the removed headlight area, and thirdly, unbolt the bottom piece of the bong. You'll need access to a socket set for that though.
Also, there are 3 bolts that hold the foglight cover in place, and they are all accessible through the bottom of the vehicle.
Sorry I don't have any pictures of the process though, but all you need is about 1/2 hour to an hour depending on how fast you work.
Old 06-10-2008, 12:21 PM   #4
sparky741
2008 VUE 2.4L
2004 ION-2 Sedan
Great, thanks! Sounds easy enough. Will get to it as soon as its less than 100 outside. Ugh!
Old 06-11-2008, 08:57 AM   #5
mrgto
mrgto will become famous soon enough
Yea, it's the old silencer mod that we used to do on Mustang 5.0's remove the silencer from the inner fender to allow more air into the engine...good for a couple of HP and maybe a MPG and some sort of peace of mind.
mrgto is offline   Reply With Quote
Old 06-11-2008, 12:19 PM   #6
saturnd00d
saturnd00d's Avatar
2008 VUE 2.4L
Yes, and I've done it to every car I've owned.
Old 06-13-2008, 10:02 AM   #7
Millhouse
Millhouse is on a distinguished road
2008 VUE 2.4L
2003 L-Series 3.0L Wagon
a little OT here, but has anyone popped the little cover on the intake hose leading from the filterbox to the throttle body. It has ecotec written on it. Its has some interesting chambers in there. It is used for sound/resonance control I assume. I wonder how different it would sound with just regular pipe between the factory airbox and the throttle body?
Millhouse is offline   Reply With Quote
Old 06-15-2008, 10:23 AM   #8
saturnd00d
saturnd00d's Avatar
2008 VUE 2.4L
Yeah it looks like a second silencer, and it's a ridiculous setup too. I am actually looking to add an intake system, bypassing this stupid (and restrictive) setup altogether. I'll let you all know how it goes once it's done.
Airflow Rate Fox Slaughter S-Series Mods 17 01-14-2009 08:47 AM
Airflow charts jentzsch23 Ion Tech 0 03-04-2007 10:59 PM
Comfort Airflow to Low? rideox4 S-Series General 3 06-18-2006 08:00 PM
A/C airflow - deflector problem? 93goldsl2 S-Series Tech 5 07-06-2005 05:17 PM
airflow through a/c vents LDB_2001SC2_#54of99 General Saturn Discussion 1 07-31-2000 09:16 AM
