Old 01-17-2018, 09:57 PM   #1
Gnarkill333
Gnarkill333 is on a distinguished road
2000 SL2
Default Swapping a 97 sc2 dohc into a sohc s chassis??? How?
Ok so my sisters car was clipped by a snow plow last night and the driver side is ruined. The engine still runs great and barely burns oil. Ripped the wheel back. There’s a few cars in my series that have blown up motors. But they are all single cam. What do I need to do to swap the dohc into the sohc chassis? Hers is a 97, and there is a 99 sc1 that looks identical to hers and a few 95-2000 sc1 / sl1 cars for sale.
Need to know ASAP
Otherwise if you are in the Midwest/Wisconsin area I have a smoking deal for you for a great engine!!!
Gnarkill333 is offline   Reply With Quote
Old 01-17-2018, 11:14 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Swapping a 97 sc2 dohc into a sohc s chassis??? How?
Others will chime in, but i'm sure you need to swap everything that the DOHC engine has...bcm/pcm, harnesses....etc.
Old 01-18-2018, 01:11 AM   #3
To put a '96-'99 DOHC into a '96-'99 SOHC...you swap engines, PCM and exhaust from the engine to the cat-con. That's all, if it's a 5spd. If it's an automatic you also have to swap to the DOHC's automatic otherwise you end up with, at best, a 1-gear-wonder transmission.
If swapping from '96/'97 to '98/'99 you have to keep the fuel rail that belongs in the car and keep the DOHC injectors with the DOHC engine.
Unless a '00-'02 engine is under $100 with a 10 year no-questions-asked guarantee, it's not worth the hassle of putting into a '91-'99.
dohc, saturn, sc2, sohc, swap
Swapping 96 SOHC engine into a 1996 DOHC car ErikTande S-Series Tech 15 07-25-2016 02:16 PM
Swapping Engines DOHC to SOHC jhart L-Series Tech 1 08-31-2013 11:22 AM
swapping SOHC for DOHC soupedupsaturn S-Series Mods 3 09-29-2011 06:19 PM
Question about swapping from a sohc to a dohc...... lonewolfncubs S-Series Mods 10 06-05-2010 01:42 AM
head swapping sohc to dohc joe's95sc1 S-Series Tech 0 03-28-2004 09:52 AM
