Old 12-26-2020, 03:23 PM   #1
GTSRider
GTSRider is a jewel in the roughGTSRider is a jewel in the roughGTSRider is a jewel in the roughGTSRider is a jewel in the rough
Default 7E8 -7E9 Codes
I just went shopping, and in the middle of my trip these codes appeared , I erased them , and the CEL immediately came back on.
Anyone ever have this happen ? What is causing this ?
GTSRider
Hudson Valley , NY
GTSRider is offline   Reply With Quote
Old 12-26-2020, 07:20 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: 7E8 -7E9 Codes
Found this explanation...Can you select them on your scanner to go deeper into the menus? Try a different scanner?
https://www.autocodes.com/qa/39930/w...-on-saturn-ion
Old 12-26-2020, 08:10 PM   #3
GTSRider
Thanks for the response....I think my brother has an in-depth scanner, I can access....but I have had a stalling issue for 6 months now, and feel I have a good hunch what it is... I will replace the crank sensor soon...any day now.... when I get the time....
Old 12-26-2020, 08:29 PM   #4
imaddicted2u
2008 AURA XE
If you decide to change the crankshaft position sensor without pulling codes, be aware there is a relearn function that needs to be done.
http://www.obd2.com/support/reprog/d...turn-crank.pdf
Old 01-16-2021, 05:00 PM   #5
GTSRider
im..... I replaced crank sensor, and now have code PO315 ....CRANK SENSOR NOT YET LEARNED .... now over 200 miles of work commuting , and engine still stalls and coughs , but not nearly as often....but even just once can get you into a rear end accident....but anyways,,,,tried the 3-4,000 rpm for 20 seconds, and nothing seems to work.... I have a GM dealer a mile up the street from me....I would take it there if they could snych CKP with ECM.
CEL is always on.... What do you think ?
GTSRider
Old 01-16-2021, 06:22 PM   #6
imaddicted2u
2008 AURA XE
A capable scan-tool is needed that has relearn CKP variability functionality. The GM dealer would be able to do it. It's a pretty simple procedure.
The relearn procedure is mainly for misfire detection so I suppose it could affect drivability.
https://www.brakeandfrontend.com/tec...set-procedure/
Old 01-16-2021, 08:37 PM   #7
GTSRider
Thanks IM.... you made my weekend.
Will have that done sometime next week.
Codes codes and more codes 99sl2 Jaybone586 S-Series Tech 4 06-06-2015 09:21 AM
Got my codes read.. the autozone rep was surprised to see soo many codes... oh no bskicrash1 S-Series General 2 11-12-2006 02:10 PM
SES Codes (beyond the paperclip codes) rkhassen S-Series Tech 11 10-18-2006 08:53 AM
OBD II codes santro L-Series General 6 09-27-2005 10:33 PM
OBD II codes santro L-Series Tech 0 08-24-2005 11:45 AM
