Old 02-19-2023, 02:20 AM   #1
JustChrisThanks
JustChrisThanks is on a distinguished road
1998 SW2
Default Pretty sure I just bought the last 21001232 (rear trans) gasket in the U.S.
Hey all, I have a 98 SW2, and I'm thinking about swapping out the 5th gear from my crashed 97 SL. Searched high and low for the 21001232 gasket mentioned in ShawnV's writeup from 2011, but it's been discontinued and seemed impossible to find. Even reached out to ShawnV to see if he had any lying around, since he was selling the gears and gasket to folks for while, but no luck. Had prettymuch given up, but found one site, oemcats I think, that claimed it was in stock at a dealership in Illinois. Called and spoke with the parts department, guy was nice but could tell he was annoyed, apparently that site is a spam site, and he gets like 50 calls a day for parts that site claims he has.
But, he put the part number in his system, and said he might have just made my day. Gave me a number for a guy in Massachusetts, called him up, sounds like the guy who's been running his own shop for 30+ years, perfect, and sure enough, he still had one of them sitting on a shelf in the back after all these years. I told him about my search and how it sounded to me like I might have found the last one, he laughed and then got quiet, I guess he looked it up in his computer, because then he said "oh wow, yeah, it looks like this is the last one listed on here in the nation".
So, that being said, is there a way I can preserve this for others? I mean, I wanna use it, but at the very least I was thinking about making a photocopy, or buying gasket paper and using it as a template maybe? Reach out to FEL-PRO or some other gasket company and see if they have interest in making them? Can't imagine they would as the demand would be so low....I feel like saturn parts are inevitably going to get harder and harder to find, and I have a unique opportunity to help preserve a small piece of their history...otoh, when I reached out to ShawnV, he did mention I can use RTV instead of a gasket and it should be fine, so it might not really matter they much at all.
Thoughts?
JustChrisThanks is offline   Reply With Quote
Old 02-19-2023, 12:33 PM   #2
bumpdraft
bumpdraft's Avatar
Location: “Is not speeding make drivers crash” ~comment by viewer of YouTube vid detailing OH Turnpike blizzard pileup 12-23-2022~
1998 SW2
Default Re: Pretty sure I just bought the last 21001232 (rear trans) gasket in the U.S.
People will just have to cut their own gasket from a sheet of gasket material.
Is there a critical dimension that needs the gasket thickness? Evidently, Shawn V says, “no”.
Old 02-19-2023, 04:36 PM   #3
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
When I recently spoke with a tranny rebuilder about my TAAT...
he noted that the output shaft nuts are no longer available, and
muttered (barely audible) they're discontinuing them.
When I bought a top 'pan' cover gasket for my TAAT last December, the NAPA
counterperson reported, 'there's only one left in our system, in Tennessee'.
Old 02-19-2023, 10:15 PM   #4
JustChrisThanks
1998 SW2
I've heard for years this is/was going to be an issue, but it seems like the wells are finally running dry. I think getting stuff from junkyards will be an option for years to come, but can't pull a gasket from the junkyard.
Old 02-20-2023, 08:49 AM   #5
TomM96
Yes. A Lot of the stuff can be found here or there (an input shaft nut
could be fabricated on a lathe) but the cost skyrockets, and convenience
disappears. The TAAT pan gasket is mostly conductive aluminum, with a
molded Oring outer edge; that would be tough to emulate ... but the
fastenings might provide adequate grounding.
Old 02-21-2023, 01:10 AM   #6
For the photo, something high-rez (default on modern phones), probably set to "macro" rather than standard photo and 2 rulers (1 each along the X and Y axis). Resizing of photo's can happen even when folks don't realize it, the rulers should allow people to get it "stretched" back to proper size.
Old 02-23-2023, 02:44 AM   #7
JustChrisThanks
1998 SW2
I like the sound of that, thank you
Old 03-24-2023, 08:38 PM   #8
JustChrisThanks
1998 SW2
Going to do the 5th gear swap tomorrow, so I finally got around to taking a photo of the gasket, just wanted to get my hands on some kind of graph paper first. Unfortunately it won't let me upload a hi-rez pic, hopefully this will be helpful to anyone needing to make their own!
Prior Saturn's
96 SL1 manual
95 SW2 manual
97 SL1 manual
Old 03-24-2023, 09:52 PM   #9
Waiex191
Waiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to behold
Waiex191's Avatar
I think I made mine, using the cover as a template. We could scan it and make it on a cricut machine now.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 03-25-2023, 03:08 PM   #10
megabyte405
megabyte405 is on a distinguished road
That's why I bought my cricut (well that and it was on super sale). Years later, we've made lots of tshirts and gifts, and approximately 1 gasket
megabyte405 is offline   Reply With Quote
Old 03-30-2023, 06:11 PM   #11
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SW2
I have a few NOS ones I can scan on my xerox along with a ruler to scale if needed.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018)
1994 Sl1 5spd: Inherited, Stock: 495,000
1995 Sl2 5spd: Retired Daily, Not Stock: 198,000
1995 Sw2 5spd: Daily, Stock: 110,000
98 SL2 Trans swap/head gasket help. 98sl500 S-Series Tech 2 03-18-2015 06:43 PM
Trans pan gasket? vanilla sky Astra Tech 4 05-07-2013 12:15 PM
Just bought 95 sl1 to have trans problems Jonallen1313 S-Series Tech 2 10-16-2012 07:10 AM
Anaerobic gasket maker for trans/rear main seal pimpin88 S-Series Tech 3 12-04-2008 11:01 PM
So I bought a Fel-Pro valve cover gasket ... kev99sl Miscellaneous Tech 4 04-19-2003 07:41 AM
