Old 11-17-2021, 09:14 PM   #1
SnowZilla
SnowZilla is on a distinguished road
Default Was told I have cracks in my Front Differential ? Should I be worried? 04 v6 3.5l AWD
Anyone elses vue have a similar issue. I was told by a welder fixing my engine cradle mounts that my front differential has cracks. Here is the picture of the area he is talking about
https://photos.app.goo.gl/LL3d2CNxPU8c19BJ9
SnowZilla is offline   Reply With Quote
Old 11-19-2021, 10:26 PM   #2
Default Re: Was told I have cracks in my Front Differential ? Should I be worried? 04 v6 3.5l
Not an expert on determining if cracks are genuine or false but there may be some ways in determining whether or not a crack in xmission cases are real or just casting marks appearing as cracks.
If a xmission case (cast aluminum) cracked, xmission oil should seep out and leave tell tale signs as oil leaks would attract dirt to mark the area of damage. Casting marks may masquerade as cracks from unfinished exterior surfaces collecting dirt, oil and debris. To separate a genuine crack from casting marks, clean the suspected area as cleanly as possible then check each day for oil leaking/seeping out and marking the cracked area. Casting marks will remain clean and free of dirt, oil and debris. In one or two days, either xmission oil seeps thru a crack or its just casting marks without a hint of damage.
Old 11-21-2021, 09:58 PM   #3
atikovi
If you're talking about those fine hairline grooves all over, most every aluminum casting I've seen has them. They form on the surface as molten aluminum cools in the mold.
Old 11-28-2021, 03:08 PM   #4
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2006 ION-2 Sedan
Oil at the bottom of the transmission is usually migrated there from the axle seals.
bad growl & vibration.(front differential ? ) 41 BigDog Vue Tech 5 01-20-2021 06:08 PM
cracks in paint saturnsctwo S-Series Tech 7 10-26-2013 07:03 PM
Radiator Cracks? slv01sc2 S-Series General 8 06-07-2008 10:59 PM
front differential seals? fngboy S-Series Tech 8 05-22-2007 09:16 PM
Tire cracks andrewe77 Vue Red Line 3 06-22-2006 08:50 AM
