Old 09-19-2021, 12:34 PM   #1
Cavell
Default Water pump bolts
03 v6. Why on earth is the water pump bolt pattern not symmetrical? There is no weep hole to orient. I changed mine for odd overheating issues and the new one leaks. I am positive the gasket surface is clean. The pump is torqued properly. And it leaks? The pulley covers the pump body so you canít see the pump unless the pulley is removed.
Water Pump Pulley Bolts & Impact Tools OldGuy43 S-Series Tech 9 08-23-2015 08:28 PM
Water pump pulley & bolts Tripp S-Series General 13 09-12-2012 12:22 AM
02 LW300 All bolts removed from the water pump pulley and it won't come off. Firestarter L-Series Tech 1 10-23-2010 09:19 PM
Water pump pulley bolts gunner3773 S-Series General 0 06-26-2007 03:08 PM
Need quick help - replacing power steering pump and water pump on V6Ö. Emanresu2 L-Series General 6 05-18-2006 05:38 PM
