Old 10-15-2012, 04:06 PM   #1
Iraqvet05
Iraqvet05 is on a distinguished road
1994 SC2
Default belt chirp...tensioner?
I replaced my alternator a few months ago and picked up some belt chirp...same frequency and indeterminacy regardless of the RPM. I did find a loose alternator bracket bolt and tightened it but the chirp is still there. While looking at the tensioner, I noticed some deflection in the pulley when I pried between the block and the pulley even slightly....time for a new tensioner or is that kind of play normal?
Iraqvet05 is offline   Reply With Quote
Old 10-15-2012, 04:35 PM   #2
Vulcansat
Vulcansat is on a distinguished road
Default Re: belt chirp...tensioner?
Put a few drops of brake fluid on the belt and see if it stops. Keep it off your paint though!
The idler has a very common bearing that went bad on mine that made a squeak when cold. Very simple to change. Like $4 a Napa. The tensioner has that same bearing as well. If the back of the belt has a gloss look at all, it maybe time to just change it.
2000 SW2
1992 Mercedes Benz 300e
2000 Dakota RT 5.9
1994 Dakota 4X4 5.2L
1990 Itasca BBC 454/400 turbo
Vulcansat is offline   Reply With Quote
Old 10-15-2012, 04:41 PM   #3
Iraqvet05
1994 SC2
The belt isn't too old but it's hard to tell when a serpentine is bad...not nearly as easy to see as the old V belts. I did hold a bar of soap against the splines and so far the chirping has stopped but I'm guessing only temporarily. The idler pulley also has play in it...I may try to find bearings for the tensioner and idler.
Old 10-15-2012, 08:16 PM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by Vulcansat View Post
...The idler has a very common bearing that went bad on mine that made a squeak when cold. Very simple to change. Like $4 a Napa. The tensioner has that same bearing as well. If the back of the belt has a gloss look at all, it maybe time to just change it.
I have written NAPA 62032 .
Searched their website, but no results found... I went there a little over a year ago and bought two. They only had two left and without checking, I bought both....One was only shielded, so my used idler pully bearing got soaked in maxima chain lube and re-installed
http://www.saturnfans.com/forums/sho...d.php?t=167813
Old 10-15-2012, 08:37 PM   #5
bumpdraft
bumpdraft's Avatar
1998 SW2
This one, looked "sealed" ...here is the one I used:
http://shopper.cnet.com/engine/6203-...-41385243.html
It is in a NAPA box and is made by SKF in Argentina
Old 10-15-2012, 09:05 PM   #6
bumpdraft
bumpdraft's Avatar
1998 SW2
Here are the actual boxes:
I guess what I am saying is RockAuto sells the whole pully for less than the trouble I went thru to get the wrong parts...
Old 10-16-2012, 11:46 PM   #7
Iraqvet05
1994 SC2
Thanks for the info. I've only used Rock Auto once a few years ago....the thing that bugs me about them is trying to order multiple parts. They may have brake pads in one warehouse and rotors in another and you have to pay separate shipping costs because of their stocking locations. I usually shop between my local chain stores (most give me a 10% military discount) and Amazon...with my Amazon Prime membership, I get most items they carry in 2-3 business days and shipping is usually included.
Old 10-17-2012, 09:10 AM   #8
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by Iraqvet05 View Post
...you have to pay separate shipping costs because of their stocking locations.....
Yes, I use RockAuto for specific parts not carried locally...
... I usually shop between my local chain stores (most give me a 10% military discount)....
Nothing beats grabbing a part locally and being done with it.
It used to be I could go to the local parts store and buy almost anything. If they didn't stock it and it would "be here next business day (could be Monday)..." they would contact the warehouse and I could drive over and grab the part.
Now, I have to wait...and it sends me to RockAuto
Tensioner rattle is back -- even with new AC Delco tensioner and belt! 2003MercMaraude S-Series Tech 18 10-15-2010 07:23 PM
Belt Tensioner Pulley and belt replacement Drumstyx7a L-Series Tech 17 12-30-2009 02:01 AM
Low RPMs braking and idle, plus a chirp, chirp, chirp. almies S-Series Tech 7 12-26-2008 09:51 AM
Serp Belt, Tensioner squeal/chirp AJT_Leo S-Series Tech 21 11-01-2007 08:49 PM
chirp from belt swzine L-Series General 5 03-21-2004 12:07 AM
