Old 07-01-2007, 02:39 PM   #1
fashions
fashions is on a distinguished road
Dizzy '99 Coolant over flow tank vent line help ? ?
help,
what is the purpose of the vent hose off the top of the coolant over flow tank going into the intake manifold? ( 1999 sl2 dohc )
in an boil over , overheat condition, or over filling the tank, wouldn't coolant get into combustion giving the impression of a bad head gasket to the non saturn tech?
water / combustion chamber....
  • was aware of water in the head / block;
  • learned of water in "wet" intake manifold at #4 cyl ;
  • now learned of hose from overflow tank into the top back of the intake
    manifold against the firewall. ??
fashions is offline   Reply With Quote
Old 07-01-2007, 10:29 PM   #2
Greg1
Greg1 will become famous soon enough
Greg1's Avatar
Default Re: '99 Coolant over flow tank vent line help ? ?
It's not a vent hose. It is just one of the misc. coolant hoses and coolant goes thru the intake not into it.
97 SW2 5-Sp 273k -mine
02 SC2 5-Sp 67k - best friend's
Greg1 is online now   Reply With Quote
Old 07-02-2007, 08:45 PM   #3
fashions
thanks greg1,
this hose runs from the top of the overflow tank- into the top back of the intake manifold. it is not the supply line next to the water filled intake port of cyl #4.
when cleaning out the intake manifold, i observed it went into the long runner of the manifold that all the cyl runners collect in.
will get a pict posted tommarrow
Old 07-02-2007, 08:56 PM   #4
eljefino
eljefino's Avatar
1995 SW1
2000 SL1
It's a de-aeration hose. Should not have coolant in it but is under the same pressure (up to 15 psi) as the rest of the system, and needs to be intact.
This burps air bubbles out of the top of the engine around back and the air finally eventually escapes through the surge tank cap.
eljefino is offline   Reply With Quote
Old 07-02-2007, 09:17 PM   #5
oseberg
oseberg is on a distinguished road
I think I get it. This vent hose isn't to vent air or fumes from coolant tank, but rather to remove air that might get trapped for some reason in the coolant passages through the intake manifold.
So if you overfill your coolant tank, the excess just leaks out through the cap and all over the place making a mess?
oseberg is offline   Reply With Quote
Old 07-02-2007, 09:33 PM   #6
eljefino
eljefino's Avatar
1995 SW1
2000 SL1
Exactly. There is nothing under the surge tank that can be damaged by coolant so it will just drip down to pavement.
Old 07-03-2007, 01:06 AM   #7
fashions
wouldn't this line from the manifold have a vacuum in it from the intake?
you bring up a good point [ elgefino ] about the water system pressure had not been thinking of that. both the tank and the manifold are open connections with no check valves of any kind.
Old 03-09-2012, 04:28 AM   #8
ahkistler
ahkistler is on a distinguished road
4.5 years later: Anyone know the part number for this hose?
2001 SL2 purchased at 131,XXX "Casey"
ahkistler is offline   Reply With Quote
Old 03-11-2012, 01:12 AM   #9
Greg1
Greg1's Avatar
That line can be replaced with hose sold by the foot at the parts store.
Old 03-11-2012, 01:42 AM   #10
wolfman
wolfman's Avatar
Yep. Rubber fuel line works just fine.
Old 01-07-2021, 02:05 PM   #11
HikinFool
HikinFool is on a distinguished road
I have been reading and researching all of these overheating topics and am still having issues with overheating and excess "backwash". I have a 1997 Saturn SL2, and have replaced thermostat, all hoses (including top and bottom hoses from Overflow tank, the de-aeration tube, radiator, and flushed the entire system. Seems to have helped the overheating issue (only gets really hot 3/4+) after sitting in traffic for extended periods of time. My issue is, once it gets hot and I park, then check coolant level after cool, I need to add coolant. My main concern is that the overflow tank ALWAYS emits excess steam (when cap is on, and when I remove cap, there is a tremendous amount of coolant that is erupting from the tank). I have tried "burping" the system as I have usually done with other vehicles, but have read here that it is not needed with this system.
PLEASE HELP!!!
Thanks!
HikinFool is offline   Reply With Quote
Old 01-07-2021, 02:30 PM   #12
Have you pressure-checked the cap, and cooling system while cold? If the system will hold proper pressure (about 15 to 18 psi), then my best guess s a bad head gasket or cracked block/head. You can rent/borrow a block leak test kit from your FLAPS, usually only paying for the chemical consumed.
You could also try pressurizing the cylinders like in a leak-down test, but that gets tricky as you need to apply as much air pressure as possible (compression is 200 psi, combustion peaks are probably over 1000 psi) and the engine will want to rotate and then open a valve. The only sure way to do this is to remove the cams... You may get *lucky* though, maybe with just 10-50 psi in the cylinder(s) you will start seeing bubbles in the coolant.
PS: Have you measured coolant temp with an immersion (meat/candy) thermometer?
billr is online now   Reply With Quote
Old 01-07-2021, 03:08 PM   #13
HikinFool
Thank you for the reply. Yes, I have pressure and leak tested the system, as well as the cap. I actually just now returned from FLAPS with test kit, and head gasket appears intact!!! All of the other information you provided regarding cylinder testing is WAY above my skill set at this point in time. I may just have to take it to shop, this thing has taxed me beyond belief. Thank you!
Old 01-07-2021, 03:22 PM   #14
HikinFool
Also, I have read that this system does NOT need to be burped, is that correct? Coolant temp at overflow is 200 degrees with temp needle between 1/4 and 1/2.
Old 01-07-2021, 03:54 PM   #15
It does not need to be burped. but that is because there is a built-in burp line. That is that small (about 5/5" OD) hose going into the top of the coolant reservoir, just below the cap. When the engine is running, you should see a steady flow of coolant coming in there, at the top of the reservoir neck.
Old 01-07-2021, 04:10 PM   #16
RobertGary1
RobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of light
1996 SC2
Back before cars had there aeration lines it took forever to get all the air out.
Old 01-07-2021, 06:58 PM   #17
Are you over filling the system? I'd carry antifreeze and do nothing unless the coolant level light came on. It may find its happy level that way.
Old 01-08-2021, 01:06 PM   #18
HikinFool
Thank you all again for the suggestions! I am weeding through all of your ideas (if I have not already). That aeration hose WAS plugged a few weeks ago, but I have since replaced that, and DO see a steady flow of coolant/air entering tank while running. I have considered that I may have overfilled system with coolant, however, I drained and refilled system and was careful to NOT put too much coolant in....My gauges indicate low/hot coolant temp while driving, even though temp gauge is sitting at 1/2. Any other ideas?
Old 01-08-2021, 02:10 PM   #19
The coolant temp light flash's for low coolant, on steady for over-temp. Either add more coolant or replace the tank (the sensor is baked into the tank) if it's flashing.
As it's a '96+ you should invest in an OBD-II reader that can get live data. I believe they start as low as $20 for the dongle plus a free app on your phone.
Old 01-08-2021, 04:35 PM   #20
That "low coolant" sensor got to be pretty flaky on my '94. I bypassed it with a small (100 ohm?) resistor long ago.
Question about coolant flow laser3kw S-Series General 26 02-19-2014 09:28 AM
Coolant Flow question. TomM96 S-Series Tech 2 10-26-2008 12:33 PM
astra transmission vent line djmtz1 Astra Tech 2 09-09-2008 12:10 PM
Fuel Air Vent Line - Leaking SeanD S-Series Tech 0 06-05-2006 09:49 AM
Coolant flow through Heater Hoses mjo S-Series Tech 4 05-30-2005 11:05 PM
