Old 05-17-2018, 10:27 PM   #1
TheBigDozer
TheBigDozer is on a distinguished road
Dizzy 2002 Saturn SL Spring special Fuel issues?
I just got a 2002 Saturn SL Spring Special and it had been sitting for 2 years. Got it fired up and drove it around town just fine but when i went to go on the highway it died like it wasnt getting enough fuel. I checked the fuel filter and the pump and everything is fine. What might be causing my problem. Once it dies it will not even attempt to fire. Once i let it sit for a while it will then start right up with no problems but as soon as i try to go highway speeds it dies again to no avail. Thanks for any imput. Also i might note that it has a full tank of fresh fuel.
TheBigDozer is offline   Reply With Quote
Old 05-17-2018, 10:56 PM   #2
toggenburg
toggenburg's Avatar
Default Re: 2002 Saturn SL Spring special Fuel issues?
Welcome to the Forum.
Spring Special? Wasn't that the Blue paint model for like $9-10K?
Anyway, how did you verify the fuel pump AND filter were working correctly?
Did you just depress the Schrader valve on the fuel rail and it spurted strongly, or did you use a pressure tester?
Old 05-17-2018, 11:06 PM   #3
billr
And, use a fuel pressure gauge with a hose long enough that you can watch FP while driving and the engine is having problems. Use live-data to check most all else. Pay particular attention to the engine rpm, either on the tach or in live-data. If rpm is getting erratic, then the CKP sensor is a likely suspect.
Old 05-18-2018, 01:24 AM   #4
TheBigDozer
I disconnected the fuel line post fuel filter and turned the key on and had great flow but just to be sure i replaced the fuel filter and still have the same problem.
Old 05-18-2018, 01:30 AM   #5
TheBigDozer
I do not have the capability to check fuel pressure or any live data. What is the CKP sensor you are talking about and what does it do?
Old 05-18-2018, 08:21 AM   #6
trottida
trottida's Avatar
Yes, 2002 SL1 with silver blue metallic paint. It's a pretty basic car and I think you're right; the special was based on price point. If you do a CarFax on the VIN it comes up in the description so it is a marketing package with an RPO code I assume.
1999 SL2 MT (311,300 km @ 01/2023)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 05-18-2018, 11:32 AM   #7
What did you replace the filter with (manufacturer and part #)? Most aftermarket filters are known to provide the wrong fuel pressure (the pressure regulator is integrated with the filter). Hopefully you got a Wix (or rebranded Wix)
crankshaft position sensor. held on by 1 x 10mm bolt (IIRC) at the back of the engine.
link explains how to replace and what it does, also has video links
http://www.saturnfans.com/forums/showthread.php?t=69687
typical failure is no spark (or injector operation) when hot, works fine when it cools down
Congrats on the new car, welcome to Saturnfans which is probably the best resource for a new S series owner, and take a moment to learn about your new car by reading the sticky thread -pay close attention to your oil levels
http://www.saturnfans.com/forums/sho...d.php?t=177672
Old 05-18-2018, 12:40 PM   #8
pierrot
pierrot's Avatar
Welcome to SaturnFans, TheBigDozer! It's a great resource for Saturn onwers.
If indeed the car has "been sitting for 2 years" then there's a high probability that some amount of varnish build up exists within the fuel delivery system. The caveat to that would be if the owner had maintained the system with a fuel stabilizer. Do you know if that was done? Gasoline goes bad when a vehicle is left without being driven over an extended period of time.
Once the your driveability issue is corrected, it seems to me that you should consider having the most complete form of fuel system cleaning performed.
401K miles (engine replaced @ 375K).
Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct.
Old 05-18-2018, 08:10 PM   #9
Saturn Night
I'm going to second the diagnosis by chaos, about the crankshaft position sensor.
You have replaced the fuel filter, which will include a new pressure regulator.
Other areas that could be suspect are the Ignition control module and coil packs, but when these go out, the car will start throwing misfire codes or won't start at all.
The fuel pump could be suspect, because it is heating up and shutting down.
www.car-part.com can be used to source parts at a slavage yard as well.
Old 05-19-2018, 11:00 PM   #10
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
ckp diagnosis was by BillR...
Old 05-21-2018, 11:51 PM   #11
TheBigDozer
[QUOTE=alordofchaos;2273425]What did you replace the filter with (manufacturer and part #)? Most aftermarket filters are known to provide the wrong fuel pressure (the pressure regulator is integrated with the filter). Hopefully you got a Wix (or rebranded Wix)
Congrats on the new car, welcome to Saturnfans which is probably the best resource for a new S series owner, and take a moment to learn about your new car by reading the sticky thread -pay close attention to .
I replaced the fuel filter with one I got from O Reillys and I'll try that crank sensor and see if that does the trick. I'll keep everyone informed on Wednesday when I am able to work on it again.
Old 05-23-2018, 11:04 AM   #12
TheBigDozer
Dizzy Re: 2002 Saturn SL Spring special Fuel issues?
New trouble shooting information! I started it up let it idle for a while and after about 15 to 20 minuets of random revving it decided to die but I noticed this time the battery light started blinking and it acted as though it lost all spark. Any ideas are very appreciated.
Old 05-23-2018, 01:29 PM   #13
floridasl22002
Spark = Have you checked or replaced the spark plugs?
Spark = How old is the battery?
Spark = Is the alternator functioning correctly?
Fuel = Is the gas in the tank 2 years old or new? Gas goes stale if not treated.
Fuel = How old is the Fuel Filter (Fuel Pump as its integral)
Air = What is the condition of the Air Filter?
Air = What is the condition of the Throttle Valve? Is it clean and the butterfly moving freely?
You probably don't need me to tell you the car needs all of the above 3 elements to start and run. You mentioned the battery light was blinking. That would tell me to check the condition of the battery. After standing for 2 years, there are lots of things that will not function first time round again, least of all the gas in the tank.
Old 05-23-2018, 01:34 PM   #14
TheBigDozer
Brand new battery brand new fuel filter butterfly is all clear and functioning new plugs and wires checked could and they are good as well.
Old 05-23-2018, 01:42 PM   #15
The battery light turning on while idling may be the biggest clue yet. It means something is wrong with main power; battery, battery cables, their connections, alternator and drive belt system. The battery light turning on while the engine's running means the electrical system is not around 14.5 volts. Lose electrical power and the car will do strange things like quitting at random.
Old 05-23-2018, 04:36 PM   #16
sedativechunk
sedativechunk has a spectacular aura aboutsedativechunk has a spectacular aura aboutsedativechunk has a spectacular aura about
sedativechunk's Avatar
I reckon this is one of the following problems:
1) Car is choking up; I recommend a complete oil change, new air filter, and adding lucas oil fuel injector cleaner with some fresh gasoline. Had a similar problem with an 04 Chevy Impala getting carbon buildup. A simple oil change and adding lucas oil can go a long way. The cars been sitting a while. Not enough to cause any serious issues, but long enough to cause problems like what you are having now.
2) Battery, as you stated the lights were coming on. Take the battery, or preferrably the whole car, to somewhere like Adavance. Have them do a battery and starter test on it, it's free. Make sure all the battery cables are nice and tight.
2) Last but not least; sounds to me like a bad fuel pump if the above doesn't fix it.
sedativechunk is offline   Reply With Quote
Tags
fuel, problem
2002 SL Spring Special Coolant Leak Officially_Nate S-Series Tech 9 08-22-2017 10:19 AM
What is special about a spring special? thyrsus S-Series General 18 07-30-2017 12:24 PM
2002 Saturn SL Spring Special ZiasNSaturns S-Series General 1 02-24-2010 08:10 PM
On the Auction Block: 2004 Saturn Vue "Spring Special" Charlie Vue General 0 01-12-2009 12:32 AM
2002 "Spring Special SL" ? 2NDSOUT S-Series General 13 06-17-2005 10:48 AM
