Old 05-21-2013, 10:04 PM   #1
Nickbo
Nickbo is on a distinguished road
1997 SL1
Wrench TAAT OverHaul Need a 2nd/Rev Needle Bearing - NEED HELP
OEM Part #21003631 is Discontinued.
As I Lifted the cage needle bearing came apart needles all-over.
Google nothing.
Any other Number I can Search?
Nickbo is offline   Reply With Quote
Old 05-21-2013, 10:26 PM   #2
Chazberry
Chazberry's Avatar
1995 SW2
2003 VUE 3.0L
Default Re: TAAT OverHaul Need a 2nd/Rev Needle Bearing - NEED HELP
Got in pretty deep, huh?
My list of parts suppliers . . .
http://www.wittrans.com/c-785-taat.aspx?pagenum=4
http://www.daccoinc.com/
http://www.transmissionpartsusa.com/
http://www.makcotransmissionparts.com/
http://www.makcotransmissionparts.com/Saturn-TAAT.html
Old 05-21-2013, 10:28 PM   #3
Get Saturn parts shows it. http://www.trademotion.com/splash/in...?siteid=214643 Look it up by part number.
Automatic transmission overhaul kits may have it as it is probably available as an aftermarket make fit part.
Old 05-21-2013, 11:35 PM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
From a Saturn Parts Supplier (local Chevy Dealer) I bought the 1/2 syncro and also bought a 2nd Gear. I bought the 2nd Gear because the parts diagram indicated it included the needle bearing (Showing it was part of a "kit")
Nope. There was only a 2nd Gear in the box.
The needle bearing might be standard??
I haven't measured anything yet...
No, I don't have a FaceBook account.
Old 05-22-2013, 12:09 AM   #5
The OP is inside of an automatic and will have to find one of the trans rebuild parts places that will talk with him.
Old 05-22-2013, 01:58 PM   #6
Nickbo
1997 SL1
This Site Part Discontinued/Un.
Old 05-22-2013, 02:06 PM   #7
Nickbo
1997 SL1
So far
Daccoinc
Transmissionpartsusa
Makcotransmissionparts
All unavailable
Old 05-22-2013, 03:13 PM   #8
Nickbo
1997 SL1
Just got off Phone
Wittrans
Unavailable
Old 05-22-2013, 03:16 PM   #9
Nickbo
1997 SL1
Still looking.
Anyone Know who Built the TAAT Transmission for Saturn/GM
Old 05-22-2013, 03:41 PM   #10
Not a clue as to the OEM supplier. It is the same bearing 91-02 so maybe the easy fix is to go buy a core at the pick and pull that still has fluid in it.
Old 05-22-2013, 05:00 PM   #11
Chazberry
Chazberry's Avatar
1995 SW2
2003 VUE 3.0L
These guys seem to be part of Trademotion, but they show availability ($27.83) . . .
http://www.mileoneparts.com/parts/in...&siteid=214336
Old 05-22-2013, 05:27 PM   #12
I think that is the same dealer I posted above. They have several names and use the trademotion catalog system.
Old 05-22-2013, 06:00 PM   #13
Chazberry
Chazberry's Avatar
1995 SW2
2003 VUE 3.0L
A while back I ordered a CKP through Trademotion, but the order was filled by MileOne. Is the Trademotion catalog tied into ALL the warehouses?
Old 05-22-2013, 06:18 PM   #14
Yes, they all use it. You can find some will show availability where none exists. I check availability by checking here, http://www.gmpartsdirect.com/ If GMPartsDirect shows no availability then you are usually out of luck. There are none on dealer shelves either. http://www.partsvoice.com/
For the cost of the bearing finding a core trans at a pick and pull is probably cheaper and once it is apart it is no longer mixed metal at the scrap yard. Might end up with a bearing and $$ left over.
Old 09-21-2020, 01:52 PM   #15
Moheganson
Moheganson is a jewel in the roughMoheganson is a jewel in the roughMoheganson is a jewel in the rough
1994 SL2
For reference purposes, the old part number was 21001512
Moheganson is offline   Reply With Quote
Old 09-23-2020, 03:36 PM   #16
Moheganson
1994 SL2
Originally Posted by Nickbo View Post
Still looking.
I'm fairly certain they built the transmissions themselves.
TAAT stands for:
"TransAxle Automatic Transmission"
I'm also guessing that if one were to measure the diameter of the shaft that goes into this part and the diameter of the bore that is goes into, and measure the height of the 21003631 bearing, you might be able to find a double needle bearing that would work by cross referencing it with specs from other bearing manufacturers as I can't imagine that they designed a custom bearing set all on their own (possible but unlikely). I'm going to try to do this and see if I get lucky.
In the mean time, I found one on eBay and bought it. Currently waiting patiently for it to arrive.
Old 09-23-2020, 03:51 PM   #17
Moheganson
1994 SL2
Here's a photo of what the part looks like:
Well, that didn't work. Here's a link:
[IMG]https://ibb.co/zPXntW7[/IMG]
1997, sl1, taat
Gas needle Crazy C S-Series Tech 16 12-05-2008 07:02 PM
Wheel bearing + grease gun + needle = good? AJT_Leo S-Series Tech 15 08-31-2007 09:40 PM
TAAT Overhaul bigc791 S-Series Tech 3 04-11-2006 10:03 AM
Where does your temp needle sit? bskicrash1 S-Series General 16 03-15-2006 05:48 PM
I need a new GAS needle! 1997_SL2 Miscellaneous Tech 2 07-03-2003 12:04 AM
