Old 07-16-2019, 05:01 PM   #21
Elliesue
Elliesue has a spectacular aura aboutElliesue has a spectacular aura aboutElliesue has a spectacular aura about
2005 VUE Red Line
Default Re: Key wouldn't turn for hours/Wheel Locked. (possible key or ignition lock cylinder
Started having the same problem with my 2005 Saturn Vue. I had been using the same key for 8 years and tried the spare. That worked for a couple of months and then had the same problem - the key wouldn't turn in the ignition. Tried WD40 and then a shot of canned air and that worked for a short time. Key was still sticking. I called the local GM dealer and brought the car in today. Much to my surprise I was told that I would be given a new cylinder and keys (which had to be ordered and will be here in a few days). Also to my surprise I was told that there will be no charge, since this was covered in perpetuity under an issue years ago that Saturns were having. No complaints there!
Elliesue is offline   Reply With Quote
1999, ignition, key, lock, sl1
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 04:30 PM
2006 saturn ion - key won't turn/steering wheel locked nurvus Ion Tech 5 06-20-2013 04:01 PM
LW300 Ignition and locked steering wheel help!! sabboo L-Series Tech 7 12-14-2010 02:29 AM
Key hard to turn in ignition - key lock cylinder? vettegofast Vue Tech 14 08-17-2010 12:25 AM
steering wheel locked cant turn key stook S-Series Tech 10 06-10-2008 11:20 PM
