Old 12-03-2005, 04:15 AM   #1
willfxp
willfxp is on a distinguished road
1997 SW2
Default When To Rebuild Engine
What determines when you should rebuild an engine, besides when it obviously does not run? Burning oil?
Thanks,
1997 Saturn SW2
willfxp is offline   Reply With Quote
Old 12-03-2005, 09:53 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: When To Rebuild Engine
Thanks,
There are other things besides not running that will make a rebuild imperative. Knocking from a spun insert for instance or very low compression in one cylinder caused by a leaking ring. However, I think you're asking about situations where the engine is not exhibiting a serious problem. That's a subjective question. When I was in college had a, don't laugh, Pinto. I carried a case of oil in the back. In the morning I would go out and put a quart of oil in it then I'd check it to see if it needed another one. Whenever I turned off the ignition, I would check the oil before starting it again. Clearly that's a case where a rebuild or a tall cliff (I really hated that car.) is called for. Most people that are inclined to do a rebuild wouldn't let it go that far. Other reasons might be for performance or sometimes just to get more familiar with the engine internals.
Old 12-03-2005, 11:31 AM   #3
amazinghl
Thanks,
Spun a bearing, rod knock, low compression... etc...
Burning oil? Just do the MMO/top engine cleaner piston soak.
00 Insight 72mpg
Engine rebuild kjtyo4 S-Series Tech 10 11-03-2009 03:28 PM
engine rebuild Big Wurmb S-Series Mods 11 08-23-2008 06:46 PM
Engine Rebuild Dragon34x S-Series Tech 2 12-24-2006 04:25 PM
Who wants to help me rebuild my engine? sps SOHC S-Series Tech 1 01-29-2005 04:17 PM
Seeking advice on engine rebuild (Subaru.. and rebuild done) Scyan Miscellaneous Tech 8 06-13-2003 09:38 AM
