Old 10-11-2005, 11:22 AM   #1
Heartbeat - '95 SL2
Heartbeat - '95 SL2 is on a distinguished road
Heartbeat - '95 SL2's Avatar
Default ignition wire/spark plug wire - resistance/ohms
Searching forum, I could find acceptable specs for wire resistance - basically what Chilton says, under 12,000 ohms. But what I need help with is reading the multimeter Googling, I only found charts similar to the one with my owners manual, but no real explanations.
Multimeter has 5 ohm ranges/resolutions:
Range, Resolution
200Ω, 100mΩ
2000Ω, 1Ω
20KΩ, 10Ω
200KΩ, 100Ω
2000KΩ, 1KΩ
Using 2 different multimeters set on 20KΩ, 10Ω setting, I get the following readings (as expected, the longer wires have more resistance):
#1 - 6.55, 6.70
#2 - 6.14, 6.06
#3 - 5.21, 5.18
#4 - 3.36, 3.35
I'm not sure how to translate into Ω or kΩ - do I multiply readings by a factor of 10, 1000, or 20K?
Just for comparison, I measured an 8Ω speaker with the following results:
200Ω, 100mΩ - 7.8Ω
2000Ω, 1Ω - 8Ω (no decimal places)
20KΩ, 10Ω - .01Ω
This leads me to believe factor is x1000, so spark plug wires range from 3.4kΩ - 6.7kΩ, still under the 12kΩ limit. Does this sound right?
I guess the multimeter owners manual expects *some* level of user competency Thanks in advance!
Heartbeat - '95 SL2 is offline   Reply With Quote
Old 10-12-2005, 12:13 AM   #2
sierrap615
sierrap615's Avatar
Default Re: ignition wire/spark plug wire - resistance/ohms
one K.ohm = 1000ohms
and yes, i would be happy with those numbers
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline   Reply With Quote
Old 10-12-2005, 09:07 AM   #3
Bill Murray
Bill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the rough
2007 ION-2 Quad Coupe
1997 SC1
From the FSM proper plug wire resistance:
Wire resistance: 1.5k-15k ohms
Old 10-17-2005, 02:09 PM   #4
Heartbeat - '95 SL2
Thanks for the input, I guess I *was* reading the multimeter correctly, LOL. Interesting the FSM has a lower limit of 1.5k - you'd think only an upper limit to resistance is relevant.
spark plug wire resistance? BASL2 S-Series Tech 1 05-06-2009 01:18 PM
Spark Plug Wire Help awhat? S-Series Tech 6 04-24-2007 10:20 PM
Ignition/spark plug wire question osp001 S-Series General 1 04-15-2007 02:33 AM
Spark Plug Wire #1... PitchBlackSC2 S-Series Tech 1 11-08-2005 10:48 AM
Spark Plug Wire Help... Rob1998SL2 Mods and Performance 8 10-16-2003 03:09 PM
