Old 11-20-2018, 11:46 AM   #1
satmark
satmark is just really nicesatmark is just really nicesatmark is just really nicesatmark is just really nice
1999 SL
Default Help-can't turn clutch master cylinder
1999 Saturn SL. I'm replacing the clutch hydraulics and the new master cylinder will not turn and attach to the firewall. I just took the old one off so I know I'm tightening in the right direction and that it only has to go 1/4 turn. It turns just a little bit and then becomes very tight. The old one came off easy but it was OEM, this is a Dorman CC649000. I've put a little silcone grease on the "threads" of the new one but it hasn't helped. Has anyone run into this or does anyone have any suggestions? I'm stuck.
satmark is offline   Reply With Quote
Old 11-20-2018, 11:50 AM   #2
Default Re: Help-can't turn clutch master cylinder
Look at the 2 parts and see what is different, correct as required.
Old 11-20-2018, 11:54 AM   #3
satmark
1999 SL
I did but didn't see any difference. However you're right, there must be something. I'll check more carefully, thanks.
Old 11-20-2018, 11:57 AM   #4
Look for scratches on the plastic of the new master? If it is catching somewhere, there should be small scratches where it makes contact
Old 11-20-2018, 12:27 PM   #5
trottida
trottida's Avatar
You need to push in and turn at the same time. Kind of like a child proof pill bottle.
1999 SL2 MT (298,000 km @ 06/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 11-20-2018, 03:24 PM   #6
satmark
1999 SL
It took a little judicious shaving with a razor blade and pushing in as I turned and then it went on. Everything is back together and it's easy to get into gear again. I used all your advice - thank you.
2001 sc2 new clutch master cylinder now no pressure on clutch rotolo64 S-Series Tech 6 10-21-2015 09:10 PM
CLutch master cylinder/slave cylinder azwesjr S-Series Tech 1 12-26-2013 10:26 AM
CLutch master cylinder/slave cylinder removal Tjflow S-Series General 7 02-17-2010 05:43 PM
Clutch master cylinder Petey S-Series Tech 8 08-07-2007 04:20 PM
difference between clutch actuator and clutch master/slave cylinder geartooth94 S-Series Tech 3 06-10-2003 12:36 PM
