Old 05-29-2013, 04:31 PM   #1
marcpilot1
marcpilot1 is on a distinguished road
Default 1994sw1 wagon/high idle then low idle
Hi all. I have a question. Am new here and hoped I could get some help. I got a sw1 with the 1.9 4cyl. Lately its been idilin low. At stop signs, at crank up in morning, etc, etc. But whats weird is it also will jump up to a high idle as well sometimes. Weird. I put new plugs, new plug wires, air filter. The car has about 180k now. Its always used mobil 1 and oil changes are done exactly on time for years. Anyway, the computer is not able to give a code they said at advance or wherever my girlfriend took it. She said they told her it was broke and needed to be replaced for 3 or 4 hund to be able to read any codes. Anyway, any help, advice, instructions would be seriously appreciated. THANKS!!
marcpilot1 is offline   Reply With Quote
Old 05-29-2013, 05:14 PM   #2
Default Re: 1994sw1 wagon/high idle then low idle
I can't believe how many people in the auto industry don't know the difference between OBDI and OBDII and when they changed over. '91-'95 Saturns are OBDI where you check codes with a paper clip, '96+ are OBDII and can be checked at the parts store.
As for the high/low idle, sounds like it's the throttle position sensor though I'm not sure if the normal diagnostic procedure works on the '91-'94 SOHC's like yours.
Rough idle and random high idle Aaron K. S-Series Tech 35 04-26-2014 06:26 PM
96' SL2 High Idle and Low/rough idle netracer13 S-Series Tech 13 04-18-2013 08:19 PM
Iacv fixed high idle now getting periodic low idle cmpcpro S-Series Tech 1 07-28-2010 10:18 PM
High idle, then low idle. IAC valve??? dwebb210 S-Series Tech 31 04-22-2010 07:53 PM
misfires at idle, high idle speed mysaturnsucks S-Series Tech 9 01-27-2005 10:27 PM
