Closed Thread
Old 01-13-2003, 11:23 PM   #1
Dano
Dano is on a distinguished road
Default 91 LS2 sudden problems with starting
has anybody replaced the fuel pump on a 91 LS2. I think I have a bad pump but I sure dont want to open the gas tank to replace it so I was thinking of getting a used tank/pump assembly. is it hard to get that tank out? is this a good idea? any input will help.
Thanks
Dan
Dano is offline
Old 01-13-2003, 11:28 PM   #2
wolfman
wolfman's Avatar
Default
I assume you mean 91' SL2? Yes I've changed at least 50. The tank (plastic) is cake easy to remove. The pump comes out just as easy. If your old worn out pump is going bad, why would you want to replace it with ANOTHER worn out pump from a junk yard? Just get a NEW fuel pump assembly and replace it yourself...normal metric hand tools and a set of car ramps/jackstands are all thats needed.
wolfman is offline
Old 01-14-2003, 12:08 AM   #3
ProDarwin
ProDarwin is on a distinguished road
Default
Gas tanks are easier to drop than you might think. I managed to drop a 20 gallon tank out of my jeep w/ 13 gallons of gas still in it. It does help to drain the tank first though. And while you are in there, I'm not sure if saturns have this, but clean out the filter before the pump. I know on the last tank I did, that thing was very clogged, and can cause some starting issues.
-Travis
ProDarwin is offline
Old 01-14-2003, 09:35 PM   #4
Dano
Default 91 SL2 sudden problems with starting
Thanks for the info!! sounds like its an easy job I think I will tackle it this weekend.
Thanks
Dan
Dano is offline
Closed Thread
Sudden tranny problems! reemoe S-Series Tech 7 08-28-2008 01:41 PM
'00 LW2 sudden onset of hard starting Blue Thunder L-Series Tech 3 03-21-2006 06:40 PM
Just Purchased 97 LS2, Starting Problems and also dies buffaluphagus S-Series General 2 02-01-2006 08:32 PM
91 LS2 sudden problems with starting Dano General Saturn Discussion 4 12-16-2002 08:41 AM
91 LS2 sudden problems with starting Dano L-Series Tech 2 12-14-2002 11:37 PM
