Old 12-01-2019, 01:22 PM   #1
satmark
satmark is just really nicesatmark is just really nicesatmark is just really nicesatmark is just really nice
1999 SL
Default Clutch slipping - how long do I have?
Original clutch - 252K miles. Starting to slip in 3rd and 4th gears. Will this get worse quickly or gradually? It's a nuisance now but would be a safety issue if it got significantly worse quickly. I drive mainly highway miles. Thanks!
satmark is offline   Reply With Quote
Old 12-01-2019, 01:37 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Clutch slipping - how long do I have?
That's not a question anyone can answer with any certainly .. could go either way, but usually, if slipping is happening, delaying the repair could cost more and more IF it got to damaging the flywheel ..... I would get that clutch and throwout bearing (etc) replaced as soon as possible.
It's been many years since I clutched my way through West Allis, WI.
Old 12-01-2019, 01:42 PM   #3
Waiex191
Waiex191's Avatar
Most likely it will go quickly. Slipping makes for more wear which makes for more slipping.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 12-01-2019, 03:15 PM   #4
satmark
1999 SL
Would you recommend replacing the flywheel at the same time if I want to increase my chances of a successful repair?
Old 12-01-2019, 04:25 PM   #5
Waiex191
Waiex191's Avatar
Good question, I'm debating that myself. We are going to replace the clutch in our '99 during winter break. When we rebuilt the car a couple years ago they took a couple thou off the flywheel as it was not in bad shape. I am leaning towards seeing how it looks and replacing if I see any obvious damage.
Bryan Cotton
Old 12-01-2019, 07:33 PM   #6
At a minimum you should have it resurfaced ($30 at my local machine shop, I assume similar rates for all) and maybe 2-days turnaround.
Last I knew S-Series flywheels were priced like gold in "new" condition, but maybe with scrap metal being so cheap the flywheel will have come down to something reasonable.
As for how long you have...the lone S-Series I had with a slipping clutch started out perfectly fine leaving my driveway then 2 miles away it started slipping then a mile later I didn't think it'd make it home. I wasn't exactly nice to it, hooning on the back roads and I think that was the one I slid off into someones flower garden and had to be REALLY not nice to it to get out...
Old 12-01-2019, 09:10 PM   #7
satmark
1999 SL
New flywheel is $55. Based on everyone's feedback I'll get it along with the clutch kit. Thanks!
Old 12-02-2019, 08:52 PM   #8
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
1997 SC2
I had some slippage, but really only noticed it when I floored it in 5th (a good test), and sometimes in 1st.
Decided to change it, and even though the wear was minimal at 140K, i did have a leaking rear seal(?). Everything was all greased up, so I replaced it with a luk kit. Resurfaced the flywheel ($40), and I was good to go. Others have gone much further on original clutches.
No slippage yet - even though I never fixed that seal... keeping my fingers crossed currently at 286k
blueknigh7 is offline   Reply With Quote
Transmission starts slipping on long trips BrianTheK Vue General 4 07-03-2014 10:46 AM
SC1 Clutch slipping Mr7mag S-Series Tech 2 04-06-2010 06:32 PM
is my clutch Slipping? kevo420 S-Series Tech 26 03-08-2008 06:39 AM
Slipping clutch Irish S-Series General 16 04-14-2005 08:46 PM
SL2 Clutch is Slipping: How Long Before I Replace? spencerb S-Series Tech 24 03-11-2004 07:45 PM
