Old 06-06-2022, 04:59 PM   #1
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Default 2002 L300 A/C problem
02 L300 with 212K miles.
A/C has always worked well until now.
A/C was not cooling. Clutch was not engaging.
Hooked up gauge set,proceeded to add refrigerant.Things seemed normal at first , but then then clutch would only engage for a second , then after a few seconds it would engage again over and over.
The low side reads really high, 100+ PSI, the high side is really low, less than 100 PSI.
What is the probably problem ? TXV ?
Thanks in advance for your help.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
lrbraner is offline   Reply With Quote
Old 06-06-2022, 08:54 PM   #2
Default Re: 2002 L300 A/C problem
Is this the first time for refilling/topping of refrigerant? Is sealer used? When connecting gauges, are gauge hoses purged of air?
Old 06-06-2022, 10:28 PM   #3
lrbraner
No, no, yes
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 06-07-2022, 06:44 AM   #4
lrbraner
I topped it off a few years ago.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 06-07-2022, 09:50 AM   #5
With well over 200k miles and topping off, the compressor cycling frequently without any more info is a mystery to me. When gauges are connected with both manifold valves closed, do you see the low side pressure drop as soon as the compressor cycles on? How long does the compressor run before cycling off? How long does the compressor remain off before cycling on? Are there any signs of refrigerant oil and dye anywhere? A uv blacklight is needed to see dye at night, under a tree or dimly lit garage.
Old 06-07-2022, 03:46 PM   #6
Rj 2000 LS2
Rj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really nice
2000 L-Series 3.0L Sedan
Have you tested the clutch relay?
Manually activate the clutch and verify it remains engaged?
It sounds more like a failing clutch or relay or both.
Rj 2000 LS2 is offline   Reply With Quote
Old 06-08-2022, 09:46 AM   #7
lrbraner
Apparently my manifold high pressure gauge has failed. Even though it never showed the high side to be over 100 PSI I had over filled the system.
Took the car to someone I know who has an A/C reclamation/ charging machine.
We extracted the refrigerant from the car, it was 2.78 lbs. Refilled with the proper amount, 2.09 lbs. System seems to be working properly now.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 06-08-2022, 11:38 AM   #8
I was a victim (from poor judgement) of a popular auto store set of ac gauges when R134a systems came out. The cheap quick connect fittings gave me trouble with minor repairs made until I decided my investment was taking more time in band aid repairs to this set. I bought a set of gauges from a well known brand similar to my original r12 set from 50 years ago. Never had trouble with the r12 set other than replacing the rubber bushings on hose ends. The r134a set is just as reliable and not that more in cost than the cheap set it replaced. My shortsightedness was thinking I wouldn't have to have many r134a repairs so a cheap set of gauges would do. I was wrong.
2002 L300 216K BCM problem? brinx L-Series Tech 7 11-12-2015 08:18 PM
2002 L300 problem PLEASE HELP! mjraica L-Series Tech 28 10-02-2010 01:44 AM
NEED HELP oil pan problem 2002 l300 GT534 L-Series Tech 2 12-20-2009 11:00 PM
2002 l300 problem jblckwd L-Series Tech 6 03-21-2009 10:15 AM
2002 L300 ECM/Battery Problem trwolf L-Series Tech 10 09-08-2006 07:08 AM
