Old 10-02-2008, 12:11 AM   #1
Garb
Garb is on a distinguished road
Default Water on the driver floor
So yesterday I noticed that my driver side mat was wet on my 01 L200. The floor is dry but the carpet mat itself is wet. Its very slight and only on the bottom left corner. But its rained for a few days here and its gotten wet enough that its concerning me. Before I bring it in to a shop, are there any usual suspects for me to check out?
Thanks in advance
Garb is offline   Reply With Quote
Old 10-02-2008, 12:48 AM   #2
Hi Phi High
Hi Phi High is on a distinguished road
Hi Phi High's Avatar
Mad Re: Water on the driver floor
It could have come from your wet feet in the rain. Mechanically, I would suspect the heater core. Is there a sweetish smell to this moisture?
Hi Phi High is offline   Reply With Quote
Old 10-02-2008, 10:35 AM   #3
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: Water on the driver floor
Heater core o rings usually leak on the Passenger side. Drivers side is usually blocked sunroof drains.
Jerry N
Groucho Marx
Old 10-02-2008, 10:45 AM   #4
Garb
Nope, its way too much to come from my feet. Also I forgot to mention I dont have a sunroof. Any other guesses?
Old 10-03-2008, 03:50 PM   #5
Ex-GMtech
Ex-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura about
2000 L-Series 3.0L Wagon
Check the A/C drain on the drivers side of the firewall/bulkhead. It will be down and to the left of the heater hoses. You can reach it from the top. Try pinching it with your fingers and see if any water comes out. It is also easily pulled off by hand.
OMG this car is easy to work on!
2000 LW2
2016 Impala
1986 GLHS
Ex-GMtech is offline   Reply With Quote
Old 10-04-2008, 10:05 PM   #6
born again
born again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to all
2000 L-Series 2.2L Wagon
How do your door seals look?
Old 10-05-2008, 09:25 PM   #7
Garb
My door seals look.... like door seals? They don't look damaged or squished. And I made sure there isnt alot of gunk in them. Its definitely rain water. It rained today and there was the usual wet spot. My headliner is dry and nothing above that spot (dash, steering wheel) seem to be wet.
Old 10-05-2008, 10:45 PM   #8
Ex-GMtech
Sounds like a possible windshield or body seam leak. Easy way to fix it is take it somewhere that do these kind of repairs(some body shops do). Have you tried cleaning out the drain like I suggested?
2000 LW2
2016 Impala
1986 GLHS
Old 10-05-2008, 11:02 PM   #9
Garb
I tried looking for it, but I'm not 100% sure of what I'm looking for, and I wasn't about to just start playing with the hoses
Old 10-06-2008, 01:40 AM   #10
Ex-GMtech
I'll try and see if I can get a picture of it for you.
2000 LW2
2016 Impala
1986 GLHS
Old 10-19-2008, 09:52 AM   #11
tburbridge
tburbridge is on a distinguished road
Dazed Re: Water on the driver floor
Same thing with my L-200, it WAS my heater core. The water usually does leak on the passenger side, but in my case the wireing harness interfered with the coolant flow and it showed up on the driver's side!! Good Luck!
tburbridge is offline   Reply With Quote
Water under my floor mats houstontexanfan S-Series General 24 05-19-2010 04:35 PM
Water on floor boards oldguard L-Series General 2 06-12-2008 09:17 AM
Wet driver front floor Ben98gs S-Series Tech 9 07-01-2007 12:52 AM
95 SC2 water in floor on driver side hpneon S-Series General 1 06-17-2006 03:19 PM
floor boards rusted at driver seat JS593 S-Series General 7 10-27-2005 03:19 PM
