Old 08-02-2022, 11:05 PM   #1
Happierfeet
Happierfeet is on a distinguished road
Default Weird misfire 2003 2.2 ion
My Girlfriend has a 2003 Saturn ion 2.2. shes had this intermittent misfire for a bit now. Not enough for a the engine light to come on but it's stored in the ecm, code po300 on my blue driver scanner. It usually happens on cold start. It'll do a couple weird misses then after about 30 seconds itll smooth out. but then it'll have misfire when revving the engine from idle speed. When a smooth acceleration is applied it's fine but sudden revs cause a miss. She does a transmission that sometimes slips between 2 and 3 but not sure if that's relevant.
I've attached some live data I thought would apply from my scanner and a video of how the car is running https://imgur.com/a/BgmHrdv
We have changed the spark plugs and gaps them correctly so far. fuel pressure is good, air filter cleanish. We put on another coilpack from my mom's hhr that's running fine and it started running harsher with the original one weirdly. I
Any guidance would be appreciated
Thank you
Happierfeet is offline   Reply With Quote
Old 08-06-2022, 07:21 PM   #2
Bessarion
Bessarion is a jewel in the roughBessarion is a jewel in the roughBessarion is a jewel in the rough
2003 ION-2 Sedan
Default Re: Weird misfire 2003 2.2 ion
Replace coil pack and ignition module. Report back.
Bessarion is offline   Reply With Quote
Old 08-07-2022, 09:51 PM   #3
Trexer
Trexer is on a distinguished road
2007 ION-2 Sedan
Does your scan tool do special tests?
Trexer is offline   Reply With Quote
Weird misfire issue Somders Vue Tech 7 03-05-2016 01:11 PM
2003 AWD V6 Misfire Issues HyperCube33 Vue General 1 01-14-2015 03:52 AM
Weird misfire issue ScentsyDiva Vue General 5 08-22-2014 04:06 PM
2003 Ion 3 misfire , had run about 2k without oil cap :( tt76 Ion Tech 11 03-14-2011 11:40 PM
Weird Misfire Huskerville S-Series Tech 5 09-14-2009 04:24 PM
