Old 07-25-2022, 03:53 PM   #1
Tschim
Tschim is on a distinguished road
Default 2008 Saturn Vue 4 cylinder
Hi, New to the forum and thanks for any help in advance. I just got a 2008 Saturn Vue and the air selection knob doesn't work, blows air but can't direct the air to the desired location. I have searched many threads on here and all seem to go in the direction of the blend actuator. Checked all the fuses and relays, ordered a new blend actuator (replaced the actuator on the drivers side), still not working. Read about calibrating the new actuator, some say it is necessary, some not but I didn't calibrate it. Tried disconnecting the battery, no luck. Is there another actuator somewhere that I am missing? I read a thread somewhere about another actuator under the passenger glove box, yes or no? Any help would be greatly appreciated. Thanks
Tschim is offline   Reply With Quote
Old 07-27-2022, 05:53 PM   #2
Tschim
Default Re: 2008 Saturn Vue XE 4 cylinder mode actuator module
Spoke to a service tech today about my issue with the 08 Saturn Vue. The problem is it will not select a different mode such as defrost or feet, etc. it just stays in one position. He suggested the following: 1. With the mode actuator wires attached but the actuator unattached and not screwed in place see if the actuator turns when you turn the mode control knob. If so it may be a bent door inside limiting it's ability to change modes. 2. He said the manual DOES call for a recalibration after installation of a new actuator. 3. He said there is a module under the rear passenger seats that is electrically in line between the mode actuator and the ac control head? He suggested to see if this was disconnected somehow or the possibility that this module is bad. 4 Next if it none of the above the next place would be the AC control head behind the dash. My question is does anybody know about the exact location and name of this module under the rear passenger seat? Thanks
Shaking Steering 2008 Saturn Aura 4 Cylinder jillybean Aura General 10 06-13-2019 08:53 AM
2008 Saturn Vue XR AWD 3.6 Sicilianking89 2008 Vue 4 03-29-2019 09:47 AM
2008 Saturn Vue thedears 2008 Vue 0 07-02-2018 10:55 AM
2008 XE Ignition Cylinder Lock Removal madmaxgt Aura General 3 12-24-2013 01:30 AM
2008 Vue 4 Cylinder DrWatt 2008 Vue 6 07-18-2008 05:41 PM
