Old 11-06-2021, 02:17 AM   #1
TheDriver74
TheDriver74 is on a distinguished road
Default new guy checking in
Title says it. 3 years ago I bought a 2000 sw2 automatic with 100k on it.I'm a pizza delivery driver so i have racked up another 107k on "goldie". Love these cars! so so very cheap and easy to work on.
couple of weeks ago i picked up a 2005 vue 2.2 5 sp manual with 86k on it. I love it!
anyway wanted to poke my head in and say hi!
TheDriver74 is offline   Reply With Quote
Old 11-06-2021, 09:24 AM   #2
Default Re: new guy checking in
welcome aboard!
Your SW2 is almost fully broken in
Dunno if you've seen post 9 in this thread. http://www.saturnfans.com/forums/sho...d.php?t=269762
Old 11-07-2021, 04:18 PM   #3
TheDriver74
i think more like post 5. 741k damn!!!
2000 SW2 207k "Goldie"
2005 Vue 2.2 "Stay Puff"
1994 Grand Marquis "Greenie"
1980 Thomas Mighty Mite
Old 11-07-2021, 06:57 PM   #4
lol, yeah, that's kinda what I meant
It's one saturnfan with 300k+ miles, telling another saturnfan with 300k miles, that their combined miles don't match highmile's mileage.
Ooooh, check this out, post 19.
http://www.saturnfans.com/forums/sho...d.php?t=164306 post 19
That was over 10 years ago, original trans and engine. Wish there was some way to get a hold of that owner (the guy that posted the pic is not the owner)
Old 11-08-2021, 12:01 PM   #5
Highmile
Highmile's Avatar
Actually 742k and holding at the moment. Pulled in the garage last night for some heavy maintenance.
Highmile
'95 SL1 742k and holding
Old 11-09-2021, 02:37 AM   #6
TheDriver74
Highmile
wow. any tips on reducing high oil consumption in these things?
Old 11-09-2021, 08:11 AM   #7
dummo
dummo's Avatar
1997 SW2
Who does your taxes? Every penny you spend on your Saturn is tax deductible. Hold onto all your receipts. Gas, your mileage delivering pizzas, parts, services, insurance, property taxes, even the cost of your internet connection to visit saturnfans.com is deductible.
That's how things work.
Also, use Walmart's SuperTech full synthetic oil and change it every 3,000 - 5,000 miles.
1994 SL1 new traded
1992 SL2 new traded for above
Old 11-09-2021, 11:26 AM   #8
What's on the agenda for your car?
Seeing as how the engine has already been rebuilt, "heavy maintenance" is kinda scaring me, lol
(I'm about to take a 5 lb sledge to break loose the wheel bearing/hub assembly off my minivan - got to the 'all the bolts are off, should come right off' stage but rust is a pretty good glue. Can't believe how many times "should pop right off" turns into "yeah, I need to get a torch / BFH / bigger BFH")
Old 11-10-2021, 08:47 AM   #9
Highmile
Highmile's Avatar
Either drill oil return holes in the pistons or replace the pistons with aftermarket units that have oil returns in them.
Highmile
Old 11-10-2021, 08:52 AM   #10
Highmile
Highmile's Avatar
It's mostly suspension work. Struts all around, lower control arms, front wheel bearings, front brakes, all fluids, plugs, wipers, rotate tires, then a good going over to make sure everything is up to the winter ahead.
Struts have about 250k on them and the lower control arms are above that. One wheel bearing was failing.
Some is probably overkill but as I've said before that I maintain this car in drive across country right now condition. No checking anything, just get in and leave.
Highmile
Old 11-10-2021, 11:48 AM   #11
Sid
Sid will become famous soon enough
Sid's Avatar
Highmile
I understand this reduces or prevents gumming up the oil rings. Does it also reduce oil consumption from day one after a rebuild? Your rebuilds use much less oil than my Saturn did since new.
96 SW2 5MT
Sid is offline   Reply With Quote
Old 11-10-2021, 10:18 PM   #12
Waiex191
Waiex191's Avatar
It did for me. My SL2 didn't really use oil until near 100,000.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 11-11-2021, 08:57 AM   #13
Highmile
Highmile's Avatar
Short answer, Yes.
My current build used a quart from 1k miles to 4k after break in of about 1k. I changed oil at 500 miles and at 1k on a new engine, always have. Since then it has been consistent 1 pint (half quart) in 5k. Very acceptable in my opinion. I think most of that gets vaporized and sucked out by the pcv.
Highmile
'95 SL1 742k and holding (hopefully not too much longer)
Old 11-12-2021, 04:49 PM   #14
Sid
Sid's Avatar
Short answer, Yes.
Highmile
That's excellent! (IMO). Mine has used 1/2 quart every 1,500 miles since new. I followed the recommended break in and even changed the oil every 3k miles or 3 months as recommended, for a while anyway until I got tired of draining out clean oil and replacing it.
96 SW2 5MT
Just checking in MikeNW S-Series General 7 10-28-2021 09:12 AM
Checking my oil slv01sc2 S-Series General 17 06-18-2007 09:30 PM
Checking oil daoyee S-Series Tech 10 09-19-2006 11:45 PM
Need help checking the oil (!) number9 S-Series General 10 03-14-2006 08:44 PM
