Old 10-01-2011, 08:59 PM   #1
LaurenBlakely89
LaurenBlakely89 is on a distinguished road
Default 2005 Saturn Ion Transmission Questions
Hey! I have a 2005 Saturn Ion 2.2L 5spd manual. I am trying to find out how to change my transmission fluid and how to fill, and how much to fill it.. Anyone out there know?
Thank You!
LaurenBlakely89 is offline   Reply With Quote
Old 10-01-2011, 09:06 PM   #2
LaurenBlakely89
Default Re: 2005 Saturn Ion Transmission Questions
Old 10-01-2011, 09:10 PM   #3
satlite440
2001 SL2
Transmission Fluid Drain and Fill
Draining Procedure
1.
Remove the left front wheel. Refer to Tire and Wheel Removal and Installation .
2.
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle .
3.
Clean away all dirt and debris from the transmission fluid drain plug area.
4.
Remove the drain plug.
5.
Allow the system to drain.
Notice: Refer to Fastener Notice .
6.
Install the transmission fluid drain plug, using pipe sealant on the plug threads.
Tighten
Tighten the transmission fluid drain plug to 38 Nm (28 lb ft).
Filling Procedure
1.
Clean away all dirt and debris from the transmission fluid fill plug area.
2.
Remove the transmission fluid level check plug.
3.
Fill the transmission with the proper fluid until even with the bottom of the fill plug hole. Refer to Lubrication Specifications for fluid recommendation.
4.
Install the level check plug.
Tighten
Tighten the level check plug to 38 Nm (28 lb ft).
Old 10-01-2011, 09:12 PM   #4
satlite440
2001 SL2
2005 Saturn ION | ION (VIN A) Service Manual | Transmission/Transaxle | Manual Transmission - Getrag 5 Speed | Specifications | Document ID: 640757
Application
Specification
Metric
English
Manual Transmission Fluid
(GM part No. U.S.: 88861800, Canadian: 88861801)
1.7 liters
1.8 quarts
Old 10-01-2011, 09:15 PM   #5
LaurenBlakely89
Thank you, but what fluid do I use to refill and how much? Do i have to add a friction modifier?
Old 10-01-2011, 09:49 PM   #6
satlite440
2001 SL2
no friction modifier and only gm manual trans fluid that is the pn i don't know of an equivalant as i work in a dealer and only use that..
Old 10-09-2011, 10:17 PM   #7
04 Ion 5speed
04 Ion 5speed is on a distinguished road
2004 ION-2 Sedan
2004
A few things I would add are: 1. make sure you can remove the fill bolt before draining the fluid. 2. clean the area around both the fill and drain bolts really well so no crud gets in with the new fluid. 3. I used Amsoil fluid in mine made my shifts much easier from almost the minute I changed it out. 4. make sure you have a funnel that you can get the fluid into the fill hole ( I used an old bottle of gear oil with the bottom cut off and it worked well. 5. Unless the 05 is different from my 04 there is no need to remove a wheel.
04 Ion 5speed is offline   Reply With Quote
Old 10-09-2011, 10:33 PM   #8
2006 ion2
2007 ION-2 Sedan
the GM manual transmission fluid is different than the dex III fluid that came in our transmissions. it's significantly improved. the GM manual transmission fluid is the ONLY fluid in existence that's to be used in our transmissions.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 10-09-2011, 10:49 PM   #9
04 Ion 5speed
2004 ION-2 Sedan
2004
Amsoil manufactures the best trans fluids imho. I went to a local dealer and he showed me in the Amsoil book which fluid they recommended in my vehicle. I then inquired at Bobistheoilguy. You can use what you want, I will go with what the guys at Bobistheoilguy.com recommend. Bottom line, it shifts perfectly now. And to be honest you could probably put almost anything in these trannys, they are pretty tough. I just don't feel the need to support my local GM dealer just because "they said so".
Tags
ion, saturn, transmission
2005 Saturn Ion Heat Questions Gillind Ion General 8 07-26-2011 09:42 PM
A new-to-me 2005 VUE- few questions joshjani Vue General 38 03-17-2009 11:27 PM
2005 3.5 Vue questions csevers Vue General 17 04-21-2007 09:55 PM
2005 Ion 3 XM Questions grebmohr Ion Tech 3 01-15-2007 11:03 PM
2005 VUE questions 2NDSOUT Vue General 11 05-06-2006 07:24 PM
