Old 10-31-2007, 12:51 PM   #1
Blammer
Blammer is on a distinguished road
1997 SW2
Default Need quick help! Intake manifold
How many bolt/nuts hold on the intake manifold on a '97 SW2 DOHC?
I know there are two bracket bolts too.
I have 6 of them off and suspect there are more but can't find them!
how many should I be looking for?
any tricks to getting it off the head?
97 SW2 270,000 miles and died when a tree fell on it.
Never argue with an idiot, they will only bring you down to their level and beat you with experience.
Blammer is offline   Reply With Quote
Old 10-31-2007, 01:04 PM   #2
kim_lombard
kim_lombard will become famous soon enough
Default Re: Need quick help! Intake manifold
There are eight - four above and for below.
there is a "hidden" one behind the power steering pump (you will have to loosen to get to it). The rest are pretty visible.
kim_lombard is offline   Reply With Quote
Old 10-31-2007, 01:07 PM   #3
Blammer
1997 SW2
thanks! I got the one behind the powersteering pump, believe it or not! the other 'easy' ones I can't find!
thanks!
Old 10-31-2007, 01:32 PM   #4
Blammer
1997 SW2
ok, ifound 7 of em where is #8 hiding?
i only found one under the power steering unit it was low, the going towards the otehr end of the engine next I found one high. between intake one and two, then one low between intake 2 and 3, the one high between 3 and 4.
then after intake four there are two, right above an below each other, then a final one on the end. which makes 7. where is number 8?
Old 10-31-2007, 01:33 PM   #5
Blammer
1997 SW2
any front facing pics of the intake would help. thanks!
Old 10-31-2007, 01:49 PM   #6
yazhere
yazhere is on a distinguished road
yazhere's Avatar
Will perusal of this site help you?
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
yazhere is offline   Reply With Quote
Old 10-31-2007, 01:52 PM   #7
Blammer
1997 SW2
thanks again! i was browsing that site while asking the question.
I found the intake manifold gasket and it only had 7 bolt holes.
I wiggled it a little and determined that my powersteering bracket was still holding it tight against the intake. loosed it and viola! it's loose!
Now my only problem is HOW do you get that stinking waterhose clamp loose that goes to the intake manifold?
the "tits" you use the pliers on are facing the firewall and there is no way to get a grip on them.
any suggestions are welcome! I may just cut the hose and be done with it!
quick question about turbo and manifold Nelsonspride S-Series Mods 9 05-20-2009 11:36 AM
Air Intake and Intake manifold carl S-Series Mods 8 03-18-2006 10:04 AM
WTB: 2000-2002 OE air intake and intake manifold Tycho Classifieds 0 03-03-2005 12:52 PM
is a '91 or a '93 intake manifold the same as a '96? sc2dave S-Series Tech 1 07-24-2003 09:16 AM
Intake Manifold + TB matt97sl2 Classifieds 0 07-29-2002 07:11 PM
