Old 06-07-2007, 12:25 PM   #1
DJboozeAlot
DJboozeAlot is on a distinguished road
DJboozeAlot's Avatar
Default TPS CE light, replaced TPS, light came back!
i have a 99 sl1 that had a CE light. had the code pulled and it was the following:
P0122
TPS/Pedal Position
Sensor A
Circuit Low Input
so i replaced the TPS and the car still idles high (1500+ rpm), studders a bit, and the CE light came back on. the battery was disconnected for about 10 minutes while putting the new TPS in, so that should have cleared the code.
what should i do next?
Awesome Backpacking Videos - https://www.youtube.com/user/MetalBackpacker
Detroit Ghetto Documentary - https://www.youtube.com/watch?v=nfxmshUEvbg
DJboozeAlot is offline   Reply With Quote
Old 06-07-2007, 05:05 PM   #2
kthane
kthane is on a distinguished road
1999 SL1
Default Re: TPS CE light, replaced TPS, light came back!
Been there; done that; got the t-shirt. Make sure you are not mistaking a bad TPS connector for a bad TPS.
kthane is offline   Reply With Quote
Old 06-07-2007, 05:45 PM   #3
DJboozeAlot
i take it that what happened to you then. was it corrosion build up on the metal prongs of the terminal, or bad wiring before the connector it self? i guess i will just look at it in the morning
Old 06-07-2007, 07:07 PM   #4
kthane
1999 SL1
Terminals of the connector were loose. I bought a pigtail replacement.
Old 06-12-2007, 09:37 PM   #5
DJboozeAlot
what is the "pigtail" replacement?
Old 06-12-2007, 09:42 PM   #6
kthane
1999 SL1
connector with short pieces of wire attached.
Old 07-13-2009, 02:18 AM   #7
Consumed
Consumed is on a distinguished road
Where did you find the new pigtail? By new, you don't mean boneyard, right?
Consumed is offline   Reply With Quote
SES light, bad idle and TPS code, some times, Help! ChuckRock S-Series Tech 5 06-25-2008 11:30 PM
2000 SL tail light/back up light problem pointyskull S-Series Tech 11 09-19-2007 05:50 PM
Tps? quiksc2 S-Series Tech 3 06-22-2007 03:17 PM
Tps dcamden Miscellaneous Tech 0 05-27-2002 11:40 AM
TPS jcesl2 Classifieds 0 08-09-2001 06:25 PM
