Old 06-28-2014, 10:03 AM   #1
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
Default successful fog lamp addition to a 2002 SL
After some solid research here, i bolted in factory fog lamps. They work great.
Best part, eBay sells complete bolt in new fog lamps with factory style brackets. Brand new lenses and bulbs. I compare them to my donor parts and they are factory quality, if you have a 3rd gen sedan, fog lamps are extremely rare and all old lenses are going to be hased. It was about 90 beans and well worth it.
Only other donor parts you need is the dash switch with the button, the front headlight harness, and the PDC (Power distribution block) from a donor with the same options your car has. I got mine from a SC2 3rd gen then just pulled the relays and fuses for power windows as mine has cranks. Too many option donor is no biggie.
One issue, the harness ground under the air pump is very corroded. Disturbing it for a new harness gave me a bad ground. I could shake it and the markers would dim or go out. I got a copper wire screw down with a single bolt hole from Home Depot. I cut the wires and put them into the screw bracket. Then i drilled a hole behind the headlights where a few pieces of metal are spot welded together. I ground the paint, drilled a leader hole, put in a good self tapping sheet metal screw and good to go.
Hope this is useful.
velleguy73 is offline   Reply With Quote
2002 Saturn L200 dashboard lamp (light bulb) replacement don2737 L-Series Tech 18 12-19-2017 07:35 PM
2002 SL1 OEM Fog lamp install 2002SATURN-PHX S-Series Mods 1 10-11-2013 12:52 PM
successful junkyard day! trouttrooper S-Series General 3 03-20-2013 12:22 AM
2002 SC2 Fog Lamp Charge Time? boomer359 S-Series General 6 08-25-2006 05:15 PM
2002 Saturn SL-2 Oil Sensor Lamp doublea S-Series Tech 9 04-26-2006 04:13 PM
