Old 09-09-2011, 07:37 PM   #1
JamesAW
JamesAW is on a distinguished road
Default L-100 - Won't start - no dash lights - then restarts
Hi there,
My 2002 L100 has 120K miles and today when turning over the ignition the car lost power and all of the lights on the dash went off.
After taking the keys out of the ignition, I put them back in and turned the key to the run position. No lights came up on the dash and the engine (obviously) wasn't turning over; no sounds were made. I tried restarting the car several times and left it for 2 minutes and then it would turn over.
I drove 10 miles away to the grocery store, returned to the car 10 minutes later, and again, no dash lights, no power, no sounds and it wouldn't start. This time I had to wait between 5 and 10 minutes before it would restart. I had tried several times to turn the engine over and had the same response: no dash lights, no power, no cranking, no sounds.
The car has had no problems starting and so this is a new phenomenon. The battery was changed about 6 weeks ago to a slightly lower rated Battery (650 CCA) after the old one failed, and I live in Georgia where cold temperature starts are rare.
I checked the fuses related to ignition and they all looked okay. I'm stumped and welcome any ideas of where to look to resolve this.
Thanks!
James
JamesAW is offline   Reply With Quote
Old 09-09-2011, 07:51 PM   #2
Sterling Archer
Sterling Archer is on a distinguished road
Sterling Archer's Avatar
2002 L-Series 2.2L Wagon
Default Re: L-100 - Won't start - no dash lights - then restarts
Thanks!
James
Pull the battery and have it bench tested (i.e. advanced). It could be that one or more of the cells are bad. It's also possible that the newer battery isn't up to the task. This test would be free too.
As you just had this put in, that's the first thing I would do. You'd be suprised the amount of screwy $h1t that can happen with even a relatively new battery (four months old, in my case). That was in a Mercedes too...the battery wasn't cheap.
Checking the fuses would have been my other suggestion, but I see that you already did that.
Sterling Archer is offline   Reply With Quote
Old 09-10-2011, 12:06 AM   #3
mattachuz
mattachuz is on a distinguished road
mattachuz's Avatar
check for corrosion on the terminals, cables and up the cable in the jacket. baking soda, water and a toothbrush will destroy corrosion on contact.
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Anahiem (disneyland): xxx
Tulare: o,(x-atleast 15)
Visalia: x
mattachuz is offline   Reply With Quote
Old 09-10-2011, 11:53 AM   #4
GM572
GM572 is on a distinguished road
Yes definitely check the connections at the battery. Same exact thing happened to mine after I replaced the battery. Corrosion caused a bad connection causing the car not to start.
GM572 is offline   Reply With Quote
Old 09-13-2011, 07:51 AM   #5
JamesAW
Hi Sterling Archer, Mattachuz, and GM572,
Many thanks for sharing your experiences, and for your advice to look at the battery, corrosion on the terminals, connections, and cables.
The cables and terminals are free of corrosion, and the car has been working perfectly for the past three days. Hopefully the situation was temporary and resolved itself.
Thanks to each of you for your support, I appreciate you reaching out.
James
Old 09-14-2011, 09:32 PM   #6
born again
born again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to all
2000 L-Series 2.2L Wagon
If the problem recurs, try cutting away the rubber coverings for the battery terminals. Sometimes these get sandwiched between the metal of the terminal and the battery post. The cover can also trap any weeping battery electrolyte and direct it down the cable, causing it to corrode.
Old 09-15-2011, 07:55 AM   #7
JamesAW
Thank you Born Again!
I will consider your tips if needed.
James
Old 09-15-2011, 04:52 PM   #8
midway
midway is a jewel in the roughmidway is a jewel in the roughmidway is a jewel in the rough
2000 L-Series 3.0L Sedan
You may also have an alternator going, I had a similar happening, it was the alternator. I had to replace it.
midway is offline   Reply With Quote
ignition, l100, power loss, start problem
Dash Lights Flicker, Won't Start kansas_blazer S-Series Tech 8 10-06-2012 09:22 PM
Night time running lights and dash lights fail Waterboy S-Series Tech 11 04-25-2012 01:35 PM
No dash lights/ Tail lights/License plat light jmelvin L-Series Tech 6 02-20-2012 03:41 PM
ON, Pump prime/dash lights okay: START, everything dead (including dome light) 200kSaturn S-Series Tech 9 02-24-2009 04:29 PM
2006 Vue AWD Radio Lights and Dash Lights Problem molinee Vue Tech 4 04-11-2008 05:56 PM
