#1 |
![]() Join Date: Oct 2010
2008 Astra XR
I'm looking at upgrading mine for something with actual diagnostic capability, i.e. fuel trim values, O2 sensor voltages, etc., and there a couple of choices from Autel, Innova, and Launch in the $200-$400+ range which I've been looking at.
Besides features, want to ensure whatever one purchased actually supports the Saturn beyond basic OBDII features. Thanks. |
#2 |
I have the ScanGauge. It was great 10 years ago but I see modern scanners have graphs and more data available.
#3 |
![]() Join Date: Nov 2021
2008 Astra XR
That price range is going to be the really good low functionality scan tools (so Global OBD2 DTC read and graphing for data but maybe not ABS/Airbag/Others and maybe limited bidirectional controls) and the really bad high functionality scan tools (Some manufacturer specific high level tests, talks to more modules but definitely not all of them).
The big questions that I think about would be is this for hobby use or for serious diagnostics? If it's for serious diagnostics, I would hold out until I could get into the $1000 range for more modern vehicles, but as the older tools are cheaper you may be able to pick up a used tool that's 10 years out of date that still covers the Astra. Are you looking at a tool that you use for more vehicles than just the Astra? Some scan tool companies sell the base tool and then subscriptions for particular vehicle manufacturers. Along with that what kind of networks are you planning to hook into? OBD1, Global OBD2, Manufacturer level OBD2, CAN network. If you visit the sites for major scan tool manufacturers like Autel, Bosch/OTC, Launch, Snap-On, etc. they often have coverage lists for their tools. So you can check for what they cover. I would look at Autel, as they are cheap, made in China I think, and have huge brass ones. They copied Ford's manufacturer level scan tool to the T or maybe D (for Ford) and put it in their tools. Ford sued them for it, I don't remember what became of it, but just google "Ford sues Autel" and you'll get some article from non-automotive people trying to write interesting stories without knowing what it's really all about. Outside of a cheap little 2 button OBD2 code reader from 2005 so the CAN DTCs don't always have a definition, I have a GM Tech 2 with the final build on it. So most GM vehicles from 1996-2011ish depending on when the architecture was converted for the GDS2. The bad part about the Astra is that it takes a special build of the Tech 2, so the whole tool gets wiped and remapped just for the Astra. So I'm leaving mine on the final build because my truck and other cars need it more. Unless I can find another one for cheap.
A wise man once tried to teach me, one project car at a time. It never stuck. https://www.youtube.com/channel/UCAiSHC8Yivs05mQnxYjx2iA 2008 Saturn Astra XR 2DR |
#4 |
2008 Astra XR
Thanks for the recommendations. I went with the Autel MaxiCheck MX808 which is the Wi-Fi model. I was able to purchase it from Summit Racing for $427 since they will do a price match against sites like eBay or Amazon, and it was $70 cheaper that way.
https://www.summitracing.com/parts/aue-mx808 So far, so good. Nice interface and a lot of features. I was interested in the live data and diagnostics features, and for a sub $1,000 unit this model has quite a bit to offer. I looked at finding the Tech2 tool, but they were roughly the same price, and I have 6 OBDII compliant vehicles of various makes, so I wanted something a little more flexible for diagnosing those. |
#5 |
2008 Astra XR
Ya, my Tech2 is ok. I bought 2 broken ones and made that frankenstein come back to life.
Does the Autel talk to very many modules on the Astra?
#6 | |
2008 Astra XR
![]() Quote:
It does. There is an Opel menu, although you have to select the vehicle parameters manually. Once there, you can perform various options such as TPMS, oil indicator resets, etc., along with diagnosing specific components. Using the OBD menu seems a bit better for capturing live data output but overall it works well for the Astra. |
#7 | |
![]() ![]() ![]() Join Date: Jan 2020
![]() Quote:
08' Astra XE 5dr 5 spd manual team2fast 200 sportcat Autolite XP5224 spark plugs GM valve cover/PCV (55564395) Side skirts SRi top spoiler SRi rear bumper skirt Illuminated shift knob |
Bookmarks |
Scan Tool | cronometro | S-Series Tech | 22 | 05-05-2016 10:56 AM |
OBD II Scan Tool | ottastra | Astra Tech | 8 | 04-22-2013 09:08 PM |
scan tool question | ncvue | Vue Tech | 2 | 07-29-2011 03:17 AM |
Scan tool software | RobertGary1 | Vue Tech | 0 | 05-13-2008 11:49 PM |
Scan Tool - Digimoto ????? | etp26 | Miscellaneous Tech | 15 | 07-05-2005 11:52 AM |
